MOTM
Re: [motm] (Gasp) Scratchy VCA pot!
2000-06-06 by Paul Schreiber
(Gasp) Scratchy VCA pot!The #1 reason is as follows:
When you are in the process of attaching the front panel, the first nut on
the pot(s) *must*
be set so that it is touching the back side of the panel. If this is not
done (or if the pcb is not
square with respect to the bracket) what happens is that the second nut
*pulls the wiper off the element*
when you tighten it! This make scratches!
I will replace any pot pot for free (even if I suspect you did this :) )
You have to be *very careful* when doing this procedure.
Paul S.
2000-06-07 by Christopher Jeris
> the pot(s) *must*
Ooh.  Paul, could you put that explanation in the instructions for future
kits?  I have been faithfully bringing the nuts up to the back of the
panel, but didn't know why until now - and if I had known, probably would
have done it more carefully.
peace,
Chris Jeris
