Re: [motm] 410 in the Poly-six (was "I'm taking a poll...")
2000-06-07 by jhaible
> > > 410 (my favorite > > > module that I may build into one or more of my Korg Polysixes)... > > > > Wow. Now *that's* a cool idea. I miss my PolySix <sniff>. I don't have a Polysix, but I have a rackmounted Polysix Chorus/Ensemble section. I often run my CS-50 thru this, and then thru an "early prototype" of the MOTM-410. For some reason, processing ensemble-type sounds with the the triple resonator is most effective. I'm also using it on the Crumar performer, which has 3-BBD ensemble effect similar to the Polysix. If you're asking me, such a 3-BBD ensemble would make some sense as a MOTM module. Probably, as in the Polysix, combined with an ordinary Chorus and Flanger function. Makes more sense from the design point of view than a combined Flanger / Echo device (which was a thread some time ago). JH.
