I always sand and primer the metal first. I don't know if the primer is
necessary, but the sanding certainly helps. Then I use Super 77 and coat the
whole mess with enough polyurethane to keep it all together. So far it's
worked fine, but only time will tell.
With permanent adhesives, you really have to lay it on and let it dry before
putting them together. If nothing you're using is working, try getting some
contact cement, the stuff they use to laminate Formica (tm) onto your
kitchen counters. Coat that stuff on, let it dry for five minutes, and I
guarantee you aren't ever going to get that paper off without soaking the
whole thing in solvent.
Good luck!
Sent: Wednesday, 12 July, 2000 12:37 AM
To: motm@egroups.com
Subject: Re: [motm] Barlow's hitting the glue again!
JB wrote:
BTW, so far the label looks quite good. I've got about 15 coats of gloss
acrylic so it's quite hard and looks kind of like my real Serge stuff
(especially with my glasses off!) -- This coating stuff I owe directly to
you
and Ken! Thanks guys! I'm not through yet however, there's plenty of chances
for me to screw it up yet!
Well, it is Ken's brainchild. I just followed his instructions.
still a stooge Larry
