Wiard Mini-wave and joystick mini review
2000-09-11 by Dave Bradley
I got a pleasant surprise today when I showed up for work - my Wiard Mini-Wave and Joystick had arrived. These are the 1200 series modules in Frac Rack format, designed to be lower cost alternatives to the significantly more expensive 300 series. Since I can't comment on sound yet, I'll just talk about mechanicals. 1202 Mini-Wave: The front panel is sturdy, and seems to be about the same thickness as an MOTM panel. The silkscreening is quite fuzzy. The pcb is mounted on small angle brackets directly to the front panel instead of to the sturdier MOTM style bracket. Both the led array daughterboard and the pcb use rather unattractive round head bright finish machine screws to mount. The pots are inexpensive open frame types that feel reasonably smooth. They are mounted too close together for my liking (Frac format sucks!) The switch feels tight and not as smooth as the NKKs used on MOTM. The jacks are of course 1/8". If I wasn't planning to trash the whole panel and MOTMize it, I'd be disappointed (mostly with the silkscreening). However, I understand that cost containment was the major design constraint here. The pcb is the same one used in the Wiard 300 series Waveform City module. It's of good quality and nicely laid out, although a couple of wire wrap jumpers appear on the back. Grant is doing a new board rev to correct this for future runs, and I believe it will also have a larger ROM to boot. I did not find any cut traces. The led array is connected with a ribbon cable, and the other panel controls are connected with (somewhat disorganized) single hookup wire (there's a good picture on the web site.) Three bare-ended power wires are soldered to the board, ready for a connector. These are smaller gauge than the standard MOTM power wires, and may not accept an MTA connector without soldering. I noticed the board was populated with big brown disc caps instead of the nice yellow box caps we are used to. Grant was pleasant to deal with and stayed in touch during the transaction. He was nice enough to volunteer to install a ZIF socket free of charge, so I can swap ROMs easily. 1209 Joystick: Not as much to say about this one. The panel has the same blurred silkscreening. There is no pcb, just a couple of transistors mounted to the pots, an led, a pushbutton, and a few resistors mounted to the jacks. The joystick has open frame pots, and feels nice and smooth mechanically. It easily stays where you leave it, even if it is mounted vertically. It has a nice spun aluminum bat handle. I was pleased to see that the gate pushbutton was a very good match visually for the pushbuttons I've already chosen for my own MOTM diy projects (his had a black bezel, mine are chrome, but size and button color are identical). Two bare ended power wires are connected. I'll be repackaging this module also into my "performance controller box". That's it for now, I'm eager to put them through their paces tonight. However, the first thing I must before I can test is to replace the jacks with 1/4" Switchcrafts. Dave Bradley Principal Software Engineer Engineering Animation, Inc. daveb@...
