MOTM
More OT: what capacitors?
2000-09-25 by Nathan Alan Hunsicker
I'm sure you're all sick of my silly questions, but I hope this will be my
last. I'm trying to build a keyboard type controller using schematics I
found on another site. My complete stupidity coupled with the vagueness of
the schematics plus an absence of a parts list has left me stumped on a few
parts needed for this circuit. There are 2 capacitors on this schematic. One
is marked 0.001 and the other is marked 1.0. I would figure these
measurements are in microfarads, but I'm just guessing. One is used in the
S&H and Glide function (1.0), the other is used between pins 1 & 2 on a
TL072 op amp (0.001). My questions are A) do these seem like normal values
for their function? B) Should these be polar caps or nonpolar?  and C) what
material should they be? (the vague instructions mentioned poly caps, but
I'm not sure if that is right) Please, somebody, help me out. Thanks -Nate
RE: [motm] More OT: what capacitors?
2000-09-25 by Tony Karavidas
Yes, *most likely* they are in uF, as in 0.001uF and 1.0uF
The 0.001uF will be nonpolar; the 1.0uF might me either depending on what
type you specify. Most likely it's a polyester film cap and will be
nonpolar.
Your enthusiasm is good, but with these questions, you might want to ask for
someone more experienced than you to check your work.
Tony
> From: Nathan Alan Hunsicker [mailto:nate@...]
> Sent: Monday, September 25, 2000 1:34 PM
> To: MOTM Newsgroup
> Subject: [motm] More OT: what capacitors?
> stumped on a few
> schematic. One
> and C) what
Re: [motm] More OT: what capacitors?
2000-09-25 by zapsn0n
from my *limited * knowledge and i would double-check it:
to be safe, i would use an audio-rated bi-polar (BP) electrolytic for the
first cap (mouser has them) and a cheap old ceramic disc (or yellow axial
ceramic, like the little motm ones) for the second. from your description
of the second's value as 0.001uF, keep in mind that that is the same as
1000pF (picofarads) which is how the catalog will list it.
you really want the help of the synth-DIY list.  sign up at
http://www.euronet.nl/~rja/Emusic/Synth-diy/
'happy harry' will jump all over your capacitor questions and you will
learn learn learn.....
mark
2000-09-25 by Paul Schreiber
Yes, microfarads. For Glide, use a 1mfd at 50V non-polar (also called
bipolar) electrolytic.
For the 0.001 (also called 1nf OR 1000pf!) use a polystyrene. Both from
www.mouser.com
Paul S.
Thanks everyone for the help, I had a small clue of what I was looking for, but needed some reassurance that I was on the right track. And thanks Mark, for the synth-diy list address, I never had it, and feel these questions would be more appropriate for that list. Thanks Again!! -Nate
Sent: Monday, September 25, 2000 4:51 PM
Subject: Re: [motm] More OT: what capacitors?
www.mouser.com
Paul S.
RE: [motm] Universal Event generator status
Hello list,
The UEG that all of you commented on a few weeks ago is coming along nicely.
There are just a few items left to finish and I hope to be building these in
about a month. I haven't quoted a price publicly, because I'm still waiting
for some quotes on materials, but I can say it will be in the high $200
range.
I think you will like the performance of this module! ;)
Tony Karavidas
Encore Electronics
http://www.encoreelectronics.com
Designers of "The best MIDI to CV converter on the planet." -Keyboard Oct.
1997
2000-09-25 by Fahl, Romeo
What is this UEG you're referring to?  I couldn't find the original
description in the MOTM archives.
Romeo
Sent: Monday, September 25, 2000 2:02 PM
To: motm@egroups.com
Subject: RE: [motm] Universal Event generator status
Hello list,
range.
Tony Karavidas
Encore Electronics
1997
2000-09-25 by alt-mode
Tony,
When do you plan to start taking orders?  Will it be offered as a kit and assembled?
     Eric
--- Tony Karavidas <tony@...> wrote:
> Hello list,
> range.
> Tony Karavidas
> Encore Electronics
> 1997
Do You Yahoo!?
Send instant messages & get email alerts with Yahoo! Messenger.
http://im.yahoo.com/
Check out:
http://www.encoreelectronics.com/motm/ENVGEN5.JPG
This is a drawing of the panel, but I assure you it's real.
Tony
> From: Fahl, Romeo [mailto:rfahl@...]
> Sent: Monday, September 25, 2000 2:04 PM
> To: 'motm@egroups.com'
> Romeo
> From: Tony Karavidas [mailto:tony@...]
> Hello list,
> along nicely.
> building these in
> still waiting
> range.
> Tony Karavidas
> Encore Electronics
> 1997
Re: [motm] Universal Event generator status
2000-09-25 by davevosh@aol.com
In a message dated 00-09-25 17:03:04 EDT, you write:
<< I think you will like the performance of this module! ;)
tony,
from what we all discussed, i think it should be a "killer" and i`m waiting
to hear when they`ll be available.
best,
dave v.
