Re: [motm] Cabinets [was: UEG.. ]
2000-09-27 by alt-mode
Steve, You can find more discussion of cabinets in the archives. I have a Moog-style "upper" cabinet that can fit 27U of modules. The outside dimensions are the same as a Moog cabinet. It is stained and waiting for me to mount the power supply, barrier strip, power distribution panels, and of course, the flat rails. I need to get 5 rails and do some work with a bandsaw to put all the rails in. I hope to send some pics to the list as I finish things up. In answer to your question, both Serge and Buchla used the same 16" boxes that can be rack mounted, if desired. Well, Serge seemed to always use them whereas Buchla varied a bit more. Many systems used the 16" boxes mounted in custom wood cabinets. Go to www.synthfool.com or www.synthmuseum.com for some pics, if you want. Eric > > How's anyone planning to do cabinets for their MOTM once the rails come out? > If I remember correctly the rails are 6 spaces wide, so for me, I was > thinking of doing two row, 6 space cabinets.. One at first and evcentually > making up another as the collection grows.. I think that three rows might be > a stretch for most people in a seated position.. Maybe a very laid back row > at the bottom and then two vertical rows, ala some older Buchlas or Serges > (which was it?) Or the always impressive top row tilting forward over the > rest of the system ala TONTO.. And of course there is always the MOOG style, > in this case it would be 12 spaces wide x two rows high with the lucky few of > us with enough modules to do another separate row on top, maybe reserved for > DOMAS and other stuff.. The size of MOTM modules will make designs > interesting, indeed.. > anyone? > ~Steve > __________________________________________________ Do You Yahoo!? Send instant messages & get email alerts with Yahoo! Messenger. http://im.yahoo.com/
