MOTM
Re: JKJ CV-5
Re: JKJ CV-5
2000-09-27 by weld@buffalo.com
My CV-5 is here finally, boy....what a nice box for the money!
Highly recommended
Jim
sikorsky wrote:
> hello all
> > Don't stick the output of the LFO into a '820 CV input would work.
> > But, you just need DC offset to avoid negative voltages. I think the
> > SAW out, with SHAPE around mid-range, will work. Check it on a 'scope.
> > This will make a 0-5V triangle.
> a gasp escapes from somewhere near the back of my mind...
> so the CV inputs should be triggered by EGs only then
> it's just that i immediately thought it would be cool to stick a load of
> LFOs into everything (my stock response to any box that has a "CV IN"
> > > or is there something already in there to stop this..?
> > Nope.
> i couldn't do something with a diode over the control inputs could i...?
> (ducking)
> > If the GATE does go to near ground (say, below 0.050V) then it should
> > BYPASS. I will test this out today and add a blurb to the manual. THe
> > pullup resistor is 2K7 to to +15V. So, you need to NOT hook it up to say
> TTL
> > outputs :) Moog S-Trig with pullup to +15V (an option of Kenton Pro-2000)
> > should work, as well as true open-collector outputs.
> or a Korg S-Trig style 5V..? (that last sentence went right over my head
> today)
> > > 3) had to look - who is "dork" in the /pix directory..?
> > Err... that would be ME, circa 1978.
> that's nothing, i was only ten then, however at least i could blame my
> parents for any fashion mistakes back then :)
> cheers
> paul b
Re: JKJ CV-5
Love the midi syncable LFO!
Highly recommended
Jim
sikorsky wrote:
> hello all
> > Nope.
> (ducking)
> TTL
> today)
> cheers
> paul b
Re: JKJ CV-5
2000-09-29 by doctorq@internet4all.net
--- In motm@egroups.com, weld@b...
> Highly recommended
> Jim
I've had a JKJ CV-5 since May, have only
used the cv and gate outputs so far. Kyle
said I should also be able to use the
sliders on my Alesis QS7 to output at the
C16/C17 jacks, assuming I can figure out
how to set the sliders to cc16/17! It's
buried in the menus somewhere, and I
haven't had the time or patience to try it.
If it works, that would make a nice
"remote control" for things like '320 rate/
shape, tuning/detuning the '300s during
performance, ect. When I first got the
CV-5, I slapped a Micronta DVM (Paul's
fave) on the CV out and saw a 2mv drift
during the first 5 minutes, after that it
was steady as a rock. I plan to install
mine inside my box o' MOTM and make a
breakout panel for it.
If you or I come up with any ideas/
questions, we should probably take it off-
list, but feel free to write me.
Chuck
