OT MIDI Merger
2000-10-15 by Al Wagner
2000-10-16 by Cary Roberts
> Does anyone know where I could find the plans or kits for a simple >2in-1out MIDI Merger? I have found them for sale but at the price of a >MOTM module!!! Since I really don't have to have one I would buy another >MOTM module!!! There is no such thing as a simple MIDI combiner. Due to running status which was in the original MIDI spec, it's not a simple task. A MIDI merge routine must examine the input, determine the length of the message and then send it out before merging data from the other input. And if one of the inputs has notes with running status, the merger must be smart enough to output the channel and message type before appending the note number. While I'm sure there a some new PICs out there fast enough to merge two MIDI streams I don't know of anyone who has made the code publically available. If you like pain and misery you can build your own 8031/51 based unit. Go here for more details: http://www.nctnico.cistron.nl/midi/midimerg.txt http://www.nctnico.cistron.nl/midi/midimerg.gif http://www.nctnico.cistron.nl/midi/midimerg.hex or in ZIP at: http://www.xs4all.nl/~leokramp/files/merger.zip I suggest saving yourself some hassle and buying a merger for $89. Or buy a used Digital Music MX-8 or JLCooper MSBrev2. -Cary
2000-10-16 by J. Larry Hendry
Used MX-8s go around $100 on e-bay. It is a great machine, and more user friendly than the JLCooper. Larry H ----- Original Message ----- From: Cary Roberts <cary.roberts@...> I suggest saving yourself some hassle and buying a merger for $89. Or buy a used Digital Music MX-8 or JLCooper MSBrev2.
2000-10-16 by ixqy@aol.com
In a message dated 10/15/00 7:47:33 PM Central Daylight Time, cary.roberts@... writes: > > Does anyone know where I could find the plans or kits for a simple > >2in-1out MIDI Merger? I have found them for sale but at the price of a > >MOTM module!!! Since I really don't have to have one I would buy another > >MOTM module!!! If you can find one somewhere (I think they are discontinued), the Anatek Midi Merger is powered by the Midi port itself. There is no other power needed. I got mine pretty cheap, like around $40 or so, and it works great. I found mine at my local music store on the bottom display, towards the back of the shelf.... There is also a company called Midi Solutions (?) that may have had a similarly priced unit. Good luck, Andrew Sanchez
2000-10-16 by Dave Bradley
--- In motm@egroups.com, "J. Larry Hendry" <jlarryh@i...> wrote: > Used MX-8s go around $100 on e-bay. It is a great machine, and more user > friendly than the JLCooper. > Larry H > I still use my MX-8 (bought brand new when it originally came out) to merge midi clock from a drum machine into the midi controller kbd to run the Expressionist. I agree, great box. Typical crappy pushbutton UI, however. Moe
2000-10-17 by sikorsky
> There is also a company called Midi Solutions (?) that may have had a > similarly priced unit. hello all, i have the Midi Solutions box, it's a 4 in / 1 out box, midi powered it cost me £90 a couple of years ago, about a year before i got myself a midi patchbay cheers paul b
2000-10-17 by ivancu@aol.com
In a message dated 10/15/00 5:11:36 PM, aardvark-mi@... writes: << Does anyone know where I could find the plans or kits for a simple 2in-1out MIDI Merger? >> Nice and inexpensive mergers (and other MIDI accessories) for low prices: http://www.philrees.co.uk/ In the U.S. you can buy them from: http://www.roguemusic.com Ivan
2000-10-17 by Andy Hartley
2000-10-18 by Al Wagner
----- Original Message -----From: Dave BradleyTo: motm@egroups.comSent: Monday, October 16, 2000 10:43 AMSubject: [motm] Re: OT MIDI Merger--- In motm@egroups.com, "J. Larry Hendry" <jlarryh@i...> wrote:
more user
> Larry H
Moe
