MOTM
Re: [motm] I've got a tube up my a**
2000-10-31 by ivancu@aol.com
I have a TubeWorks Blue Tube that I use for everything from warmth to crunch.
 There is a two-channel rackmount version that is quite nice too.
One thing you have to watch, especially with high-output devices like MOTM,
is that you keep your input level to the unit fairly low so that you can
maximize the range of sounds within the device.  Otherwise everything will be
massively distorted (sometimes good).
Ivan
Re: [motm] Re: I've got a tube up my a**
2000-10-31 by John E Blacet
I'm curious as to how you fixed the power supply?
(I'm sorry if this is veering off-topic...)
Regards.
John Blacet
Blacet Research Music Electronics
http://www.blacet.com
blacet@...
Are you on our mailing list?
http://www.blacet.com/mailform2.html
In a message dated 10/31/00 5:13:05 AM, synth1@... writes:
<< It means no way in HELL am I offering a module with a 250V power supply.
How about as a D-I-Y kit without the PSU?  Sort of an experimenters kit?
Ivan
2000-10-31 by John Speth
I bought a PAIA Tubehead and, after fixing the underdesigned power supply, I got a real nice tube preamp. I'm far from being a tube expert but I know it runs the tube at about 35V by stepping up the 9V delivered from the wall wart. (Isn't this called "starved plate" design?) It's not the best sound but it's compact, relatively cool (low temp) and does wonders for overly clean signals.
I would think that most tube preamps are not MOTM compatible because the 10V MOTM signal levels would be too much for useful operation. I'd love an MOTM VC tube preamp! And maybe 250V in the circuit just isn't necessary.
John Speth
Molectron Detector, Inc.
http://www.molectron.com
mailto:johns@...
2000-10-31 by Dave Bradley
supply, I
Oh yeah? What fix did you make? I've got a TubeHead collecting dust
because of the noisiness and underwhelming sound. I can only get it
to crunch, it's not subtle at all.
Moe
2000-10-31 by J. Larry Hendry
I own a Tubehead. I like it OK for what it does (great organ distortion for those Deep Purple like tones). However, it is not the sound I am looking for. You are right about the (starved plate design being a very low voltage). However, that is more of an abortion of the signal than the pushing into the non-linear response area.
The 10 volt MOTM signal level is not a problem in my opinion (as unprofessional as it is). Buffer and isolate in, buffer and isolate out. I see no reason that the many tubes (including the fine 12Au7 twin triode) cannot operate with plate voltage around 90 volts.
I'm not trying to twist any arms. I'm just seeing if anyone has cool ideas they want to share.
Larry H
Sent: Tuesday, October 31, 2000 10:29 AM
Subject: [motm] Re: I've got a tube up my a**
John Speth
mailto:johns@molectron.com
collecting dust because of the noisiness and underwhelming
sound. I can only get it to crunch, it's not subtle at all.
My point exactly concerning TubeHead sound.  Good for "that one" sound, but
not for subtle introduction of harmonics.  Yes.  Inquiring minds want to
know what kind of power supply changes you made.  However, I still don't see
that design doing what I am really looking for.
Larry H
2000-11-01 by Paul Schreiber
WHaaahahahahahaha! (evil laughter)
Paul S.
always a step ahead
> How about a module to introduce even-order harmonics, like an 'aural
> exciter' module? Rather than going for just "distortion," which is kinda
> colloquial for odd-harmonic distortion.
2000-11-01 by jwbarlow@aol.com
In a message dated 10/31/2000 6:40:19 PM, synth1@... writes:
>Paul S.
>always a step ahead
Good to hear! Of course the logical extension of this is go VC "distortion,"
and VC odd to even (kinda like through zero). This would really compete with
the Wave Multipliers!
JB
I'm really interested in what you find here Larry. I have a PAiA "Stack in a
Box" (which neither sounds like a stack, nor comes in a box!) which is the
guitar optimized Tubehead. I find I need to use other pedals to get it really
nasty sounding -- I find the knobs labeled "Drive" and "Crunch" to be rather
misleading. I agree with your idea about this kind of circuit not pushing the
signal to go nonlinear, which would be more interesting and useful.
I should look at the other commercial products that were mentioned
(especially for my guitar) and I think we've previously discussed that
saturating the output transformer has a lot to do with the grinding sound
which I'd like to get. And of course VC inputs would make this very useful
for many modular applications. I think Eric Barbour had a tube based
wave-mangling device (possibly VC but not a kit as I recall) which got some
good reviews on diy. I can't remember the name of it though.
JB
In a message dated 10/31/2000 3:42:21 PM, jlarryh@... writes:
>Re: I've got a tube up my a**I own a Tubehead.  I like it OK for what it
RE: [motm] Re: I've got a tube up my a**
2000-11-01 by Tkacs, Ken
Good! Good! Stay ahead!! :-)
Sent:	Tuesday, 31 October, 2000 8:48 PM
To:	motm@egroups.com
Subject:	Re: [motm] Re: I've got a tube up my a**
Paul S.
always a step ahead
