MOTM
joysticks and nuts
joysticks and nuts
2000-12-05 by J. Larry Hendry
Some parts people have asked about in past posts:
These are great nuts to add for the panel backside of pots that only come
with one nut.
Electronic Goldmine:
part # G145  10/$1   50/$3.
Ferrite beads (for each module's power supply input filter as Paul has
taught us:
part # G8902  10/$1
I got a joystick from them that is the first one I think is just right for a
1U MOTM panel (if you were to want such a panel).  It has two good feeling
Alps 150K pots but they are open carbon.  But, larger than many of the ones
commonly found on joysticks.  And, this is the first cheap joystick I have
seen that looks like it could be re-fitted with better pots (plastic shaft
only like the Blue Bornes jobbies as some custom cutting and fitting would
be required.
part # G0600  $2.49.
Stooge Larry
