MOTM
420-A-Go-Go
420-A-Go-Go
1999-07-05 by Tentochi
Well, Paul had me up till 2:30 last night, soldering and twiddling.
1 down, 1 to go.
The HP/Notch/LP switch seems to have no affect.  No clicks or pops or
changes in sound when I switch it.  Seems to always be in ?lo pass? mode.
I made a mistake???
Bad switch???
It is working right and I don't know what the hell I am doing???
Poor design??? (Not likely)
The Frequency knob is not quite what I expected either.  Often it will peak
in the middle of the setting.  This is probably me not understanding the
designing.  I understand the relationship to the Q and the FREQ--a two
handed job to ride the edge!
Signed,
Sleepless in Seattle
Note:  If Paul hasn't shipped yours quite yet, it is worth the wait.  If you
haven't ordered a couple yet, why the hell not?!?!  My head got knocked up
against the wall a couple of times by it last night.
WHEEEEEgrgrgrgrgrgrgrgrgrgooooowwwwwwwwhhhhhhhhheeeeeeeeeeEEEEEEE!  Actually
with some deft know twisting, a lot of vocal formant type sound can be
coaxed out of it.
Re: 420-A-Go-Go
1999-07-05 by JWBarlow@xxx.xxx
My filter works as expected, so you may have wired your switch up wrong
(which I've done many times in the past). I also don't understand what your
references to FREQ peaking in the middle of travel, and what you mean by the
Q and FREQ having to be operated at the same time to "ride on the edge."
Again, this is not what I'm experiencing with mine if I understand you
correctly.
I could post a few simple tests for general operation if you continue to find
problems after verifying the correct flying wires.
John B.
In a message dated 7/5/99 10:26:23 AM, tentochi@... writes:
>I made a mistake???
>Bad switch???
>peak
Re: 420-A-Go-Go
1/2 finished with 2nd unit.  Let me get it finished and see what happens.
Thanks John!
The max Q (before it starts self-oscillating) does not remain constant as
FREQ varies.  In order to get the max Q, you have to slightly change it
while moving the FREQ knob.  I don't think most people care about this,
so...  I am unusual and really try and push it.  I played for 2 hours today
with the filiter self-oscillating.
I don't understand the FREQ on this unit fully to know if it is a problem or
not.  If it is totally different that the 2nd one, I will have Paul take a
look at it.  But that is a ways off.
More this evening...
--Todd
> From: JWBarlow@... [mailto:JWBarlow@...]
> Sent: Monday, July 05, 1999 3:06 PM
> To: motm@onelist.com
> Subject: Re: [motm] 420-A-Go-Go
> From: JWBarlow@...
> what your
> mean by the
> correctly.
> continue to find
> John B.
> >I made a mistake???
> >Bad switch???
> >peak
> --------------------------- ONElist Sponsor ----------------------------
> With more than 20 million e-mails exchanged daily...
> http://www.onelist.com
> ...ONElist is home to the liveliest discussions on the Internet!
