Proofing Part #2
2001-01-08 by Paul Schreiber
At www.synthtech.com/demo have corrected Page 2 and uploaded the back cover (not much going on there) Note I switched to Acrobat 4. If you can't read the files, get the free upgrade at www.adode.com Paul S.
2001-01-08 by Brousseau, Paul E (Paul)
In the 420, first bullet, I think you need another comma after the "and": "LP, HP, and Notch responces". In the 900 section, first bullet, what is "(typ)"? Do you mean "typical"? If so, spell it out! At first, I thought you might have meant "type". Again, I was not an english major! --PBr
> -----Original Message----- > From: Paul Schreiber [SMTP:synth1@...] > Sent: Sunday, January 07, 2001 7:31 PM > To: MOTM listserv > Subject: [motm] Proofing Part #2 > > At > > www.synthtech.com/demo > > have corrected Page 2 and uploaded the back cover (not much going on > there) > > Note I switched to Acrobat 4. If you can't read the files, get the free > upgrade at www.adode.com > > Paul S. > > > >
2001-01-08 by Tkacs, Ken
"Typ" seems to be more of an engineer's thing than actual English. Regarding commas, as a few have pointed out, this is funny because a while ago we had a knock-down drag-out brawl over this very subject while preparing our 7"-thick Y2K Manual. We had executives arguing with us and each other over petty wording and everyone could produce a book showing that they were correct!! The bottom line is that when grouping things, as: "...one, two, or three..." You *are* supposed to have a comma in front of the "or" or "and" as the case may be. However, older style guides may not show it, or indicate that it is optional. Modern usage demands it. We found that people over 45 here generally insisted that there was no comma and under that insisted that there _should_ be one. We finally contacted the Queen of England or something and supposedly got the definitive answer on the subject. By the way, we were told that with bullet points, a similar usage is required: * One; * Two; and, * Three. When done in formal style.
-----Original Message----- From: Brousseau, Paul E (Paul) [mailto:noise@...] Sent: Monday, 08 January, 2001 11:03 AM To: 'motm@egroups.com' Subject: RE: [motm] Proofing Part #2 In the 420, first bullet, I think you need another comma after the "and": "LP, HP, and Notch responces". In the 900 section, first bullet, what is "(typ)"? Do you mean "typical"? If so, spell it out! At first, I thought you might have meant "type". Again, I was not an english major!
