proofreading page 1
2001-01-08 by Dave Bradley
2nd paragraph: "New modules are always in de sign" remove the space.. Under general specs or somewhere you need to tout that this is a large format panel synth, not cramped! MOTM-101: White, pink, and slow random OUTPUTS. Unique vibrato OUTPUT The 101 has panel dimensions in units, the others don't Both AC and ???? cut off! MOTM-120 Hyphenate as sub-octaves instead of suboc-taves and the individual suboctaves are ??? cut off MOTM-300 has linear AND exp FM, you just mention linear did you mention the 4 waveforms available? text is cut off after "new timbral possibilities with audio-" Dave Bradley Principal Software Engineer Engineering Animation, Inc. daveb@...
