MOTM
[motm] MOTM-700 VC Router
2001-01-29 by elhardt@aol.com
Today I'm hearing my MOTM for the first time.  The only mistake I made was
swapping the FM1 and FM2 pots on one of my 420 filters (easy to correct).
Everything else in my blue case seems to work fine, except the behavior of
probably the simplest module (MOTM-700) is strange.  I can plug in an LFO,
VCO or EG and watch the LED go from red to green based on the CV input.  But
I have to set the knob/switches down to between -4 and -5 to see that happen.
 With no cable in the CV input, I can't turn the switch and see the LEDs flip
as the manual indicates.  There are no adjustments on the board.  Both
channels behave exactly the same.  It does switch between two different audio
inputs and therefore seems to function.  It almost seems like the values of
the pots are wrong yet they match the manual.  Has anybody seen this problem?
 If not, I'll have to troubleshoot it.  Thanks.
-Elhardt
Re: [motm] MOTM-700 VC Router
2001-01-29 by James Hendry, Sr.
Since both channels behave the same, I might suspect
the regulated reference voltage (12 V+ and 12 V-)
supplied by U6 and U8.  Check the voltage present at
the each end of the pots.  If I am doing the math
right, you should have about +5.1 VDC on one side and
-5.1 VDC on the other side.  If you don't have that,
check your regulators U6 and U8.  Are the inserted
correctly?  What is the voltage on the ouput pins?
Larry
> except the behavior of probably the simplest module
> (MOTM-700) is strange. ....snip....
> But I have to set the knob/switches down to
> switch and see the LEDs flip as the manual
> board.  Both channels behave exactly the same.
> -Elhardt
Do You Yahoo!?
Yahoo! Auctions - Buy the things you want at great prices.
http://auctions.yahoo.com/
Re: MOTM-700 VC Router
2001-01-29 by mate_stubb@yahoo.com
Did you forget the little jumpers on the cv input jacks from ground
lug to normalling lug?
Moe
made was
correct).
behavior of
an LFO,
input.  But
that happen.
LEDs flip
Both
different audio
values of
this problem?
> -Elhardt
Re: [motm] Re: MOTM-700 VC Router
mate_stubb@... writes:
>>Did you forget the little jumpers on the cv input jacks from ground lug to
normalling lug?<<
That was a good suggestion.  It sounded like that might have been it, but I
checked and they are there.  In fact if I just insert an unconnected plug
into a CV jack, the LED turns green.  There is some info in the manual about
what voltages I should be seeing on certain pins on the chips.  I'll have to
check that out.  The module basically works, it's just that the knobs seem
way off and don't behave like the "Preliminary Check-Out" in the manual.
-Elhardt
