MOTM
[motm] Roland 1 volt/oct accuracy / FM1-FM2 swapped
2001-01-29 by elhardt@aol.com
I just pulled out my two 420s (one where I swapped FM1 and FM2 by accident),
and popped in my two 440s.  They sound great, but I had swapped FM1 and FM2
on both of those too.  Geez.  No wonder, the damn numbering of pots on the
front panels of those filters is jumbled.  1,3,2 and 5,7,6.
I'm using my Roland SH-7 to control my MOTM using the CV and Gate outputs
(with a mess of alligator clips and resistors to chop down the gate level).
I measured the CV out on the bottom C note and got a reading toggling between
2.00 and 2.01.  Up the octaves I got 3.00, 4.00 and 5.00 exactly.  I had no
idea that both the synth and my BBC meter were so accurate.  Both the synth
and meter would have to be accurate to less than 1/100 of a volt for these
kinds of readings.  Amazing.
-Elhardt
RE: [motm] Roland 1 volt/oct accuracy / FM1-FM2 swapped
2001-01-29 by David Bivins
I've built two 420s, two 440s, and a 410 (among many others), and I never
swapped any of those pots. No wonder, I followed the damn instructions and
PCB labeling.
Feeling cheeky, not enough coffee yet, just kidding you, Ken... ;)
David.
> From: elhardt@... [mailto:elhardt@...]
> Sent: Sunday, January 28, 2001 11:37 PM
> To: motm@yahoogroups.com
> Subject: [motm] Roland 1 volt/oct accuracy / FM1-FM2 swapped
> FM2 by accident),
> swapped FM1 and FM2
> of pots on the
> Gate outputs
> the gate level).
> toggling between
> exactly.  I had no
> Both the synth
> volt for these
> -Elhardt
> eGroups is now Yahoo! Groups
> Click here for more details
> http://click.egroups.com/1/11231/0/_/529958/_/980743045/
> -------_->
Re: [motm] Roland 1 volt/oct accuracy / FM1-FM2 swapped
2001-01-30 by elhardt@aol.com
dbivins@... writes:
PCB labeling.  Feeling cheeky, not enough coffee yet, just kidding you,
Ken... ;)<<
Yes, or course, the instructions.  I think that is why I got the first one
right.  I built the other three later on and followed the PCB labeling only,
and that was what led me astray.  I have noticed many inconsistancies from
module to module when it comes to wire color and where it's attached to.  If
you build a bunch of different modules in parallel assembly line fashion as I
do, it only makes for potential errors.
-Elhardt
