MOTM
Re: [motm] Blacet Miniwave??not a vco
2001-02-01 by J G Wong
Miniwaves are not vcos
I have a few wavetable vco pbs for  the proper individual.  It is pretty
simple ,  takes a 2716 or 2720 wavetable.  one can easily clone ,
Basically Identical to Digigsound or Ken Stones (Sasami). and I think
Modacan (not sure)
G Wongi
Tentochi wrote:
> John is still being very vague on this which makes me a little worried.
> Give us a little more hint of what is going on John!
> If this falls through, I am will to help buy the plans from Grant and fire
> up more Stooge mayhem.
> If that falls through, we could all center our forces on the Modcan's
> Wavetable 19A module (http://www.modcan.com/modhtml/modules.html).  They are
> $250 each.  We could maybe do a custom conversion and panel or work
> something out with Modcan.  Does anyone have one of these?
> >From the website:
>    WAVETABLE 19A
>         -tracks pulse from standard VCO
>         -provides 64 waveforms in 8 banks with 8 locations
>         -uses technology similar to PPG or Prophet VS for digital waveforms
>         -trigger inputs for stepping banks and locations
>         allowing wave sequencing
>         -can be used in LFO range for modulation
>         -hard sync input
>         -Led numeric display
> So no one gets the wrong idea, I would rather buy one from Paul.  But on
> several occasions, he said he wouldn't be doing one.  And secondly, I would
> rather buy the Blacet/Wiard model.
> Cheers!
> Shemp
>    wavetbl[1].jpg    Type: JPEG Image (image/jpeg)
>                  Encoding: base64
Re: Blacet Miniwave??not a vco
2001-02-01 by mate_stubb@yahoo.com
I've explained this several times, but let's be clear:
It is correct that the MiniWave is not a VCO - it requires one to
drive it only if you are using it to play back wavetables. It also is
NOT a clocked wavetable device like the DigiSound VCDO or Modcan. The
wavetable position is determined directly by CV, not by advancing the
count on an internal clock. THAT'S why the MiniWave is much more
flexible than a clocked device, and why it can do things like
quantize an input voltage into scales, or perform Serge-like
transform functions.
It is an arbitrary transfer function generator, with the transfer
functions encoded into ROM. No more, no less!
Moe
pretty
think
> Modacan (not sure)
> G Wongi
worried.
and fire
Modcan's
work
> > >From the website:
> >    WAVETABLE 19A
waveforms
> >         -hard sync input
But on
secondly, I would
> > Cheers!
> > Shemp
> >                  Encoding: base64
