OBERHEIM SYNTH group photo
OBERHEIM SYNTH
Index last updated: 2026-04-28 23:39 UTC
Oberheim Matrix 6 Display Issues?
2016-02-19 by fknchino@...
Hey everybody!
A while back my Matrix started playing up one day at a friends house and kept on turning off randomly.
One day I took it home and from what I can remember, the sounds were completely off and the display was jumbled, then shortly after it stopped turning on.
I performed a diy fixes myself and replaced the caps and rails, assuming it could have been a PS problem.
Replaced some buttons, bought and replaced some CEM chips, replaced the battery, hell I even replaced most caps with 'audiophile' grade nichicon caps for fun.
Currently, I've got my Matrix 6 with a tech right now and he thinks there might be something wrong with the display- hence why the matrix isn't booting at all.
The power supply was tested and found nothing wrong.
It's been over a few months and I havn't brought it up since, he suggested it could be a tricky job trying to identify the root cause.
Can anyone help with this?
Would love to see this baby home safe soon.
Re: [oberheim] Oberheim Matrix 6 Display Issues?
2016-02-19 by Bob Grieb
Pretty sure the CPU does not read anything back from the display, so
if the display is not working, it should not prevent the synth from working.
Does the synth do anything at all?
The display uses a higher voltage than the rest of the circuits.   If that's not present,
then the display would not work, but everything else should.   Also, there is a fuse
on the front panel board for the display voltage.  You might want to check that.
Are you saying that you replaced CEM chips as preventive maintenance?
If so, can I have the ones you removed?  :-)
Bob
On Fri, 2/19/16, fknchino@... [oberheim] <oberheim@yahoogroups.com> wrote:
 Subject: [oberheim] Oberheim Matrix 6 Display Issues?
 To: oberheim@yahoogroups.com
 Date: Friday, February 19, 2016, 11:36 AM
 Hey everybody!
 caps for fun.
 nothing wrong.
Re: Oberheim Matrix 6 Display Issues?
2016-02-23 by fknchino@...
Hey Bob, Thanks for the reply.
Haven't tested the audio outputs yet, the audio out board assembly was fully disconnected at the time I gave it to my tech, worth a try
I forgot to mention I also replaced the CPU.
Some of the CEM chips I replaced had broken pins, hence the replacement.
Once the synth is fixed I'll get back to you on the condition of the chips and if you're interested in them.
Any possible scenarios you could come up with?
Appreciated
G
Re: [oberheim] Re: Oberheim Matrix 6 Display Issues?
2016-02-23 by Bob Grieb
As your tech should know, after checking the power supplies,
you would check the oscillator to the CPU, and also the reset signal
to the CPU.   If those are OK, then try reading the EPROM that holds
the code, to make sure it's still intact.   (At some point you may also
want to upgrade to the one that's on my site, tauntek.com, but only
after you get it fixed)   If everything is OK so far, then scope the
address and data lines coming from the processor and look for strange
voltage levels, which would indicate a signal that is shorted to vcc or gnd.
But test the synth first to see if maybe it's working and just the display
is bad.   That would be a different situation.
The service manual for the Matrix 6 is available, so your tech should
get that if he doesn't have it.  It's a free download.   It least then he will
have the schematics.
Bob
On Tue, 2/23/16, fknchino@... [oberheim] <oberheim@yahoogroups.com> wrote:
 Subject: [oberheim] Re: Oberheim Matrix 6 Display Issues?
 Date: Tuesday, February 23, 2016, 1:59 AM
 #yiv2231702039 #yiv2231702039 --
2016-02-23 by Malte Rogacki
Another thought:
I believe the service manual for the Matrix 6 has some errors with regards
to the display.
If I recall correctly the service manual specifies 2x9VAC as coming from
the transformer (at least on the block diagram) but in reality it's 2x42VAC.
What I also found a problem occasionally is the multi pin connectors
between the boards. Contact problems with those can result in strange
things including garbled characters.
Of course "Reset and initialize" should probably be performed first. At
least in one case this was already enough to bring a Matrix 6 back to life
that otherwise  behaved very erratically.
