KLM367A clone capacitance measurements
2010-11-12 by Malte Rogacki
Hello everyone; since I wanted to get to the bottom of the capacitance problem with some KLM367A clones I got me a dedicated capacitance meter and did some measurements on various old and new boards. All measurements were done on populated boards with the processor removed. I measured: pin2 of IC22 socket to TP3 (that's essentially the capacitance across C22 to ground) pin3 of IC22 socket to TP3 (that's essentially the capacitance across C23 to ground) pin2 to pin3 I realize the absolute values probably don't mean too much; however it should still be possible to compare the overall behaviour. The picture is quite clear IMO. All measurements in pF. The percent value is the difference between the first and second column. board pin2 pin3 pin2<->pin3 percent old1 40.7 46.7 92 14.7 old2 32.2 36.1 89 18.3 new1 23.1 28.7 81.3 24,2 new2 24 33.5 56.6 39.6 new2 (mod1) 19.0 18.4 53.0 -3.2 new2 (mod2) 26.0 40.5 58.5 55.7 board "new2 (mod1)" has two 10p caps installed, "new2 (mod2)" has two 33p caps. A couple of weeks my guess was that the difference between the two "clock legs" becomes too great for some boards to properly function. The above measurements seem to point into this direction as well. I have some more half-finished clones on which I will do additionla measurements once they I finished them. I have no idea why the overall capacitance for board "new2" was significantly lower than for board "new1"; I also don't know if this may affect operation. Ideas? Comments?
