no output except static and clicks!
2013-06-11 by zumdar
I have a problem with my Korg Polysix that I really need some expertise on. I'm playing a big festival this weekend and I need it for the gig!
I bought this Korg Polysix from Switched On Music in Austin, TX and shortly thereafter I started having battery leakage problems. The dudes at the store took it back and completely replaced the old KLM-367 board with the leakage on it with a completely new clone KLM-367 board. I received it back in January with the new KLM board so I don't think this new issue is due to battery corrosion.
Now the P6 won't output any real sound. I turned to volume pot up all the way and get some static and messed with every single knob and button and the only thing that I get is a weird clicking noise when I switch it to PWM mode and the clicking frequency changes with the PWM SPEED knob.
Other small things to note: The LFO led is completely lit now and won't respond to any adjustment made to the LFO SPEED knob.
Also (and this was actually a problem the last couple of times I played the synth), the effects SPEED/INTENSITY knob will effect the volume (which right now is just the clicking and static, but all last week it was effecting the total volume of the synth).
Does anybody have any places I should start with troubleshooting? I do have some intermediate synth repair knowledge and I can definitely make my way around these things, I just have never really learned how to start going about troubleshooting. Any suggestions would be supersupersuper appreciated! We are leaving in a few days, and we have practice everyday until then!!!
Thank you sooo much for any help you can provide, please bestow any wisdom on me o knowledgeable synth ones!
(time to go pour over the schematics and see if there is some link between all these things! ahhhhh!)
Re: no output except static and clicks!
2013-06-23 by tonezone020
When you got it back with the clone it was working ?
If you open it up can you see the voices being triggered by each key press - an led lights up on the 366 voice board...
Try reseating the connectors - I've had problems due to that.
Just in case you can't get it sorted in time, find someone you can hire a P6 from...
Tony
Re: [PolySix] no output except static and clicks!
2013-06-23 by Malte Rogacki
This COULD at least partly be a problem with the KLM368A board (the effects
board).
You may want to check if you get a signal at CN14 on the voice board. This
is the actual output of the voice board; the signal then passes through the
effects board.
Sometimes the effects board can also get damaged from battery leakage
(because it's next to the battery).
2013-06-26 by Djé
I think you have a problem with the +15v on the KLM-376
Checks if the +15v comes well at CN01,02,13,16 Pin1
& tell us,
Djé
2013-06-26 by Djé
& tell us,
Djé
2013-07-20 by zumdar
Ok, so I went and bought the KiwiSix KLM-376 upgrade board and it definitely works better now...... but there are now a few very frustrating problems that weren't there before. Soooo..
1. now the keyboard isnt in tune anymore, like you play an octave and it is slightly off and the amount of being out of tune gets worse as you go lower on the keyboard. Im getting this totally weird microtonal stuff when I try to play, which is cool...but that's not what I'm trying to do right now!
2.   Also....the effects knob is acting weird. When I go down to past about 4, all sound cuts off. No matter what effect is on or even if the effects are off. The effects still work, but just as long as it is over 4. When you get over 4 though the knob starts acting like a volume knob and when you get to 10, the keyboard is reallllly loud.
3. The arpeggiator button doesnt work anymore. Maybe the button died and I need to replace it? Is there a way to engage the arp without the button?
4. The poly button in the Key Assign section doesn't work anymore. When I start the keyboard up it is lit and I can pay polyphonically, but if I go to unison mode, I can't switch back to Poly mode.
5. The Chord Memory LED doesn't work anymore but the button does.
ughhh man you fix one problem and it leads to 5 more....I guessing I should go through the calibration procedure in the service manual to at least try to fix the first problem, but I dont have an oscilloscope right now.
Thank you for any help you kind and generous Polysix gurus can offer a straggling one.
-william
Re: [PolySix] Re: no output except static and clicks!
2013-07-20 by tonykirby100@yahoo.co.uk
Hi William,
I had a similar problem with my effects section and it was showing exactly the same symptoms as yours. I managed to obtain a replacement output/effects board from a friend of mine. This cured my problem and I was informed that it is likely to be that the board is in need of calibration.
What is clear from my experience is that when the boards are not calibrated correctly they can act unpredictably.
At least you know the fault you are experiencing in point 2 is directly related to this board. Good luck and hope you get to the bottom of it.
Tony
> -william
2013-07-20 by chipaudette
Have you downloaded the service manual?  Follow the procedure that follows all the schematics.  It starts with the power supply (*always* start with the power supply) and moves on from there.  You'll need a digital multi-meter to measure voltages.  Do you have a multi-meter?
Assuming that you do, the service manual starts by measuring voltages in the power supply.  If the power supply voltages are OK, the manual moves on to check the other circuits.  I'm thinking that you're going to find that the problem is with the digital-to-analog conversion (DAC) circuit or analog-hold circuits that follow the DAC circuit.  But that's just my conjecture...
Start the procedure in the service manual.  At some point, you'll get completely wacky results that are not what the manual says you should get.  Try the remedy that the manual suggests (usually, it's simply turning a pot).  If the remedy doesn't work, let us know where in the procedure your Polysix deviates.
Chip
Whoa, my bad...I was in "topic view", which means that I only saw your initial post from a month ago.  I see that there's been lots of action since then.  Sorry for my pointless old-news reply!
Chip
> Chip
RE: no output except static and clicks!
2013-09-08 by <wbkennedy1@gmail.com>
Is there a way to test if the buttons are messed up or if its a larger problem? nothing happens when I push the arpegiator button..
Chip
> Chip
RE: RE: no output except static and clicks!
2013-09-08 by <chipaudette@yahoo.com>
There are a bunch of reasons why a button won't appear to work:
(1) is the button itself working,
(2) are the traces between the button and the microcontroller working,
(3) is the microcontroller that's scanning all of the buttons working,
(4) is the microcontroller outputing the correct signals in response to the button being pressed,
(5) is the synth correctly acting on the microcontroller's commands
It's definitely easiest to start with (1). Turn off your synth. Open it up. Find the part of the PCB holding the button in question (the Arp button?). Take your digital multimeter, set it for measuring resistance, and measure the resistance across the leads of the button. It should be high (or infinite) resistance when the button is not pressed. When you press the button, the resistance should go to zero.
If you don't see this behavior, you might need to replace your button. If you decide that this is the best course, you can check-out my page that describes the process in detail:
If the button seems to work OK, you'll need to start working down through the rest of the debugging list at the top.
Good luck!
Chip
