Re: Stackcables...
2010-03-11 by gcmci
Although the $8 price is higher than some of the hundreds of other patch cables that I have, having 12 of these in the 3 different lengths (4 per that is) is a godsend when patching keyboard voltages and it makes patching devices triggered by a common source easier to trace. The quality of the cables is quite nice - they are quite flexible and the jacks stack very nicely without too much force. Just using these guys when patching in my Pressure Points to trigger a patch makes it more direct - when I do use a mult (like on the bottom of a 300 series module, I now have 4 outputs from the mult - often, I would have to use two mults just to have four gates or four CVs.... Of course, that's just opinion - I could be wrong...8*) gary --- In wiardgroup@yahoogroups.com, John Mahoney <jmahoney@...> wrote:
> > The point of having mults available at every output is to encourage > signal splitting. You avoid the mental resistance -- the "oh, I have > to unpatch this cable, patch in a multiple or Y-adapter, and then add > another cable" factor. > > I think the cables are reasonably priced when you consider the > avoided cost of mults and/or adapters and add the benefit of patching > spontaneity. > > But, hey, to each his own. Lots of folks think that Wiard modules are > expensive. > > John >
