New Roms; first impressions and a few concerns....
2003-10-19 by sincultura13
I bought the Pop and Protean drums and after about 2 hours with them
on my XL-7 this are my first impressions....
POP Rom: I bought it as replacement for my aging QS8 thinking I was
going to get better sounds and to not to have to log that 50+ lbs
keyboard around.... I'm still going to have to take my QS8 when I
need to play acoustic/electric piano, organ and/strings. The QS8 as
old as it is sounds better in that deparment. The Winds I didn't like
too much either, but being a sax player I'm never happy with them....
Was I dispointed at that point? Not really... My first thought
was: 'for $100 why should I be...'  Then I started to preview the
rest of the sounds and found tons of usuable stuff! Lots of lounge-
like sounds I didn't have. When I started tweaking sounds I started
to get happier and happier. The presets on the XL-7 were not
something I could relate to at first since I mostly hear non-synth
music, the POP on the other hand is really usefull for me because
even the sounds that don't sound realistic I can tweak them into
something I can use... Is like they come from a sonic place I
understand. Is like I have new palette to paint with.  I bet is
probably the same thing for people who like synths... to me they
pretty much all sound the same. :( Or like this rocker friend of mine
who told me that all Jazz solos sound the same and I told him that I
felt the same way about heavymetal solos... hehe! Anywho, I couldn't
be happier... I'm going to be getting alot done faster (since the
sounds are inside the XL-7 and tweaking them is a pleasure) and
tweaking sounds I can relate to is most inspiring!
PROTEAN (otherwise know as drum) Rom: The first thing I thought about
was the cymbals... Realm was right, the decays is very natural! I
started to audition deferent kits and was very impress with some of
them. But was still, under the impression that some samples I've
gotten free with magazines or on the web were a little better...
After banging on the pads for a good half hour I decided to download
the Protean Patterns. BTW, It takes a while 'cause you have to
manually change the bank of each Pattern on the file before you load
them to your XX-7 so it doesn't over write your sequences. It was
then that I remembered something: The important thing with sounds,
specially drums, is not how they sound by themselves but in the mix!
The Protean acoustic sounds have character,  most of the wave samples
I have don't. Then again  I've never tried a really good drum sample
cds, so I don't know how they'd compare. The acoustic sound on the
rom have this organic quality to them which make me want to play
them... I don't know if Emu actually sampled drum kits but at least
it sounds like it. Some of the kits make me feel like I'm on a mixer
room listening to a mic'd drum kit.  Patterns are not bad either, I
feel like I got a new drum machine, there's quite a few snare and
bassdrum patterns I can use...
Concerns:
1) After I installed the roms I got a pretty bad ground noise, but
after I made sure all the screws where really tight it went away
almost completely. I still can here a faint hum on the back but so
far away that I don't think its going to make a difference. Infact
it's so faint it might have already been there before I'm not sure...
2) Since I installed the drums there's been two time where one quick
edit knob has turn the light by itself. The first time I wasn't sure
which one it was either the 'Filter Cutoff' or the 'Amp Attack'...
the second one was the 'Filter Cutoff' for sure. Is that normal?
Also I notice that with some pads on the POP rom the 'Filter Cutoff'
doesn't turn off no matter which side I turn the knob to...Is these
normal? Any suggestions as to what might be the cause? I was thinking
it might that my keyboard is sending a cc or maybe there's a pinched
ribbon on the XL-7 but since it's only done it twice I want to wait a
bit before I reopen it... I get all nevous when I open electronic
equipment.
I want to thank Realm and all the people who by sharing with me their
knowledge helped me decide that these roms was what I needed....
Re: New Roms; first impressions and a few concerns....
2003-10-19 by M2
--- In xl7@yahoogroups.com, "sincultura13" <sincultura13@y...> wrote:
"BTW, It takes a while 'cause you have to
them to your XX-7 so it doesn't over write your sequences."
Within E-loader, once you add the patterns to be loaded, you can
hilight them all and then change the bank designation for them all
at once without doing them individually.
Just an F.Y.I.
2003-10-19 by M2
......when you open up the sequence downloader, select downloader
again from the tool bar and there will be a prompt available for
edit destination.
load
> Just an F.Y.I.
2003-10-20 by sincultura13
Thanks, I knew there had to be an easier way... It didn't work for me
though. Are you using ver1.1?
> edit destination.
> load
all
> > Just an F.Y.I.
I got it! I have to press "CTRL I" on my versions... Damn, I need to
start reading the manuals more often... :(
me
> > edit destination.
> > load
can
> all
> > > Just an F.Y.I.
2003-10-20 by M2
Glad you got it to work.  Yes, CTRL I works the same too.  BTW, I'm
on E-loader version 1.1 and OS 2.0 on the XL.
You have to first add the files to be downloaded to right hand side
of the sequence downloader box(on the right), single(left) click on
one pattern, then CTRL A to select all and then the prompt I was
talking about is now hilighted.
to
for
> me
downloader
for
> > > edit destination.
<sincultura13@y...>
you
> > > load
> can
them
> > all
> > > > Just an F.Y.I.
2003-10-20 by realm619
Highlight all of the source Patterns and Press CTRL+I.
rEalm
me
