The obvious method, of running tracks of different lengths or time
signatures in parallel, is not possible on the XL7. You can cheat by
using longer sequences - for instance, a 12-bar pattern with tracks
in 3/4 and 4/4 - but this is clumsy and won't work in many instances.
You're in luck, though: what will work is to use the arpeggiators.
They'll loop at whatever length you determine, so you can easily play
different time signatures against each other. If the note or notes
triggering the arp are recorded into the pattern (instead of played
live), the arp will be retriggered each time the pattern loops, which
will throw this off. To avoid this, add a "sustain pedal=on" event
(CC #64 of >63) to your pattern so the note is held across the
pattern loop rather than retriggered. Now the polyrhythm will last
until you change patterns. Just watch out for stuck notes.
This should probably be added to the Tips and Tricks file, btw.
--- In xl7@yahoogroups.com, "elemental" <adz32@y...> wrote:
> I know this is probably not possible...
> but, is there any way of achieving polyrhythms in the XX-7?
> That is one reason I am thinking of getting an RM1x or something
just
> for the polyrhythmic stuff.
> Its not something I would use in every track, but live sequencing
> would really lend itself to the use of different time signatures.
