Low Digital output
2003-12-03 by rajah_patel
hi i used to have an XL7 now an XL1 -turbo what i don't understand is why the SPdif digital out has such a low output. also if you want to sample sounds off it is it best to use the Digital output and then normalize or should you just sample off the analogue "Main outs"? thank you kindly
2003-12-03 by Aaron Eppolito
Quick lesson on digital audio math: One full scale 16 bit sound = 16 bits. Two full scale 16 bit sounds = 17 bits. Four full scale 16 bit sounds = 18 bits. 128 full scale 16 bit sounds = 23 bits. Difference in volume bewteen 16 bits and 23 bits = 42dB. Essentially what all this means is that a 128 voice sampler needs to have 42dB of headroom to ensure that no digital clipping occurs. However, if you record the S/PDIF output, normalizing will *ALWAYS* sound cleaner and be more high-fidelity than recording the analog mains. Always, always, always; no exceptions. The same digital signal that goes to the S/PDIF jack is the same one that goes to the D/A converters. It's not like there's a separate "gain-reduced" version that goes to S/PDIF. D/A then back through A/Ds NEVER improves fidelity (though it may color the sound which may or may not be a good thing). --- rajah_patel <rajah_patel@...> wrote: > why the SPdif digital out has such a low output. > > is it best to use the Digital output and then normalize > or should you just sample off the analogue "Main outs"? __________________________________ Do you Yahoo!? Free Pop-Up Blocker - Get it now http://companion.yahoo.com/
2003-12-03 by erik_magrini@Baxter.com
What if my S/PDIF cable is dirty though? rEalm However, if you record the S/PDIF output, normalizing will *ALWAYS* sound cleaner.... ------------------------------------------------------------------------------ The information transmitted is intended only for the person(s)or entity to which it is addressed and may contain confidential and/or legally privileged material. Delivery of this message to any person other than the intended recipient(s) is not intended in any way to waive privilege or confidentiality. Any review, retransmission, dissemination or other use of , or taking of any action in reliance upon, this information by entities other than the intended recipient is prohibited. If you receive this in error, please contact the sender and delete the material from any computer. For Translation: http://www.baxter.com/email_disclaimer ============================================================================== [Non-text portions of this message have been removed]
--- vibesart <vibesart@...> wrote: > Great post Aaron. Given this neccesary situation w/re to headroom, > does this mean that (presuming a 16 bit D/A) the "low level" > S/PDIF signal is not a full 16 bits - i.e. like 8-12 bits or > something, given that level corresponds directly to bit depth in > digital audio? I think the S/PDIF is 20 bit, but I don't really recall. It might be 24 bit, and it might depend on the S/PDIF / AES Pro setting in the global menu. > Is the D/A in the XL7 16, 20 or 24 bits? 24 bit, but converters never achieve the accuracy of their input. Even the best converters out there get about 18-20 bits resolution (106-118dB SNR) and that's not even counting THD. -Aaron __________________________________ Do you Yahoo!? Free Pop-Up Blocker - Get it now http://companion.yahoo.com/
