Sysex Remote Control
2003-12-19 by Matt Picone
Is it possible to select/queue patterns (during playback) remotely on a
command station using sysex?
Re: Sysex Remote Control
2003-12-20 by steve_the_composer
> on a command station using sysex?
I haven't done E-Mu sysex in months, but I seem to recall that there
are no sysex transport functions available via regular sysex or by
remote control sysex.
You might be able to do it via remote sysex by paging through menus
and cursor positions (button/knob simulation).
I used this technique with two test projects:
(1) automatically ramdomizing and saving a bank of presets
(2) automatically storing multisetups in specific locations.
The pattern view will allow you to cue the next pattern.
1.  Place cursor under Next Pat value
2.  Rotate the main knob
3.  Press enter
When the current pattern finishes, the queued pattern will start.
That's basically it.  If you have done remote control sysex
programming, it shouldn't be too difficult.  It may just take some
time to develop the right algorithm for your needs. If you haven't,
it will probably take a while.
Caveat: I have done remote control programming on the P2500, but from
what I can see it should be the same under any E-Mu running OS2.0.
Footnote:  I am in much need of income, so if you are interested in
contracting out the programming, I would be happy to work on the
project.  (Contact me privately.)
Hope this helps.
--Dr. Steve
2004-01-23 by honkeyhindu
can someone explain why this does not work ....
if i set  up two patterns  and record in a sequencer( sonar ) the
events that i do .. ie  the process in which i change the
patterns ..when i go back and playback the sequence that i have
recorded the pattern change does not take place ..
there is definately a huge string of systex data recorded during the
change but its does not take palce ..???
there
> 3.  Press enter
from
> Hope this helps.
> --Dr. Steve
Re: [xl7] Re: Sysex Remote Control
2004-01-26 by erik_magrini@Baxter.com
Pattern Changes aren't transmitted as MIDI out.
rEalm
honkeyhindu <honkeyhindu@...>
01/23/2004 10:55 AM
Please respond to xl7
        To:     xl7@yahoogroups.com
        cc:
        Subject:        [xl7] Re: Sysex Remote Control
there
> 3.  Press enter
from
> Hope this helps.
> --Dr. Steve
Yahoo! Groups Links
To visit your group on the web, go to:
 http://groups.yahoo.com/group/xl7/
Your use of Yahoo! Groups is subject to:
 http://docs.yahoo.com/info/terms/
The information transmitted is intended only for the person(s)or entity
to which it is addressed and may contain confidential and/or legally
privileged material. Delivery of this message to any person other than
the intended recipient(s) is not intended in any way to waive privilege
or confidentiality. Any review, retransmission, dissemination or other
use of, or taking of any action in reliance upon, this information by
entities other than the intended recipient is prohibited. If you
receive this in error, please contact the sender and delete the
material from any computer.
For Translation:
http://www.baxter.com/email_disclaimer
