world rom / copy cords
2004-01-22 by phest2k
Can anyone explain why the patchcords on the world expidition ROM are
not compliant to the xx7 knobs like they are on the MP7 pure phatt
ROM. I presume its because the W.E ROM origionates from a p2k module
with only 4 realtime controller knobs but this doesn´t explain why the
pure phatt has its cords cofigured to 16 knobs. Didn´t the pure phatt
also come from the mo´phatt with only 4 controllers?
Q.2 Why isn´t it posible to copy cords for all layers (LA->LA) from
one preset to another? V. time consuming :(
thx
:p
Re: world rom / copy cords
2004-01-22 by steve_the_composer
> thx
> :p
The sysex manual lists copy utilities.  The copy preset layer
patchcord sysex allows for LA as a destination. but you can only have
one Layer as a source.
You might be able to use a set of 4 sysex commands to do L1->L1 . . .
L4->L4 in one motion.  However, I am not sure if this solution would
work for you.  It would take more time to write the commands than to
do it by hand.
Re: [xl7] Re: world rom / copy cords
2004-01-22 by aeon
> to do L1->L1 . . . L4->L4 in one motion.  However,
> I am not sure if this solution would work for you.
> to do it by hand.
the first time anyway! ;)
programmed into a buttonpress on, say, a Peavey
PC1600x, it might be quite handy!
cheers,
aeon
The PC1600x may be handy; never had one.  But for this task, I'd
guess it wouldn't save time.  Each sysex command specifies source
preset, source layer, destination preset, destination layer, and
Source ROM.
--Steve
2004-01-22 by aeon
> Source ROM.
oops, gotya...no need then.
cheers,
aeon
MIDI2Arp
2004-01-22 by Stu
Can someone re-upload or email me the MIDI2Arp app that kevinj_j did back in
September?
I can't seem to dowlaod it from the files section...
Stu
Re: MIDI2Arp
2004-01-23 by phest2k
Hi Stu.
Its still in the files section here on the left.
Great App.For anyone new here, check it out!
:P
 --- In xl7@yahoogroups.com, "Stu" <routerman@z...> wrote:
> Hi,
back in
> September?
> Regards,
> Stu
2004-01-23 by steve_the_composer
> are not compliant to the xx7 knobs like they are on the MP7 pure
> phatt ROM.
Just wondering if you ever solved this one.  (I assume you checked
controller assignments/settings [patchord/preset], so I didn't
mention it.  If you take a look at the manuals for different gear,
they show different default controller assignment/settings.)
--Steve
"steve_the_composer" <smw-mail@p...> wrote:
"Just wondering if you ever solved this one"
It´s not too much of a problem,really. It´s just that I´m used to the
phatt rom presets where the patches are fairly consistent to the
labels on the xx7 chasis, for example :
midi I is patched to the velocity amp
midi L is patched to Lfo2 rate -etc,etc,etc
 - it does what it says on the box.....
however, the world rom presets have:
the midi H patched to lfo2 rate (not amp release)
no midi contr. is patched to the velocity amp - etc
It´s just really inconsistent and takes ages to reconfigure.
Seems like the world rom was made for a different machine and I was
just curious which one.
:paul
ps: I´m really struggling to get my head around remote sysex commands.
Could you recommend some literature.I´d love to understand it but its
so tricky- my achilles heal .
> > phatt ROM.
> --Steve
2004-01-23 by Aaron Eppolito
The World ROM (and every other rom except XL-7, MP-7, PX-7 and POP) is
laid out for the Proteus 2000 knob layout.  It's as follows:
A: Fc,  B: Q,  C: Shape (usually Filt env to Fc),  D: Image
E: Attack,  F: Decay/Rls,  G: Movement (usu. panning),  H: Rate (of G)
I: Velocity->Amp,  J: Vel->Fc,  K: FX A,  L: FX B
There's some variation on these (like the B3) but in general, they
follow this layout.
-Aaron
> It\ufffds not too much of a problem,really. It\ufffds just that I\ufffdm used to the
Do you Yahoo!?
Yahoo! SiteBuilder - Free web site building tool. Try it!
http://webhosting.yahoo.com/ps/sb/
Thx Aaron/Steve,
Just wanted to make sure it was installed correctly.
I´ll have to free up some more user locations and do some patchwork
then :/
BTW - Some excellant sounds on this rom - well recommended.
:Paul
is
G)
> follow this layout.
> -Aaron
> Do you Yahoo!?
P2K Controller defaults/ P2k knob assignments/P2k knob layouts
2004-01-25 by steve_the_composer
Aaron, thanks for the details!!  I have taken the liberty of:
(1) renaming the thread for easy access via search engine (I hope!!!)
(2) reformatting your list vertically
--Steve
> is laid out for the Proteus 2000 knob layout.  It's as follows:
 A: Fc
 B: Q
 D: Image
 E: Attack
 F: Decay/Rls
 H: Rate (of G)
 I: Velocity->Amp
 J: Vel->Fc
 K: FX A
 L: FX B
> follow this layout.
> -Aaron
Re: [xl7] world rom / copy cords
2004-01-26 by erik_magrini@Baxter.com
Great idea!
rEalm
thx
:p
Yahoo! Groups Links
To visit your group on the web, go to:
 http://groups.yahoo.com/group/xl7/
Your use of Yahoo! Groups is subject to:
 http://docs.yahoo.com/info/terms/
The information transmitted is intended only for the person(s)or entity
to which it is addressed and may contain confidential and/or legally
privileged material. Delivery of this message to any person other than
the intended recipient(s) is not intended in any way to waive privilege
or confidentiality. Any review, retransmission, dissemination or other
use of, or taking of any action in reliance upon, this information by
entities other than the intended recipient is prohibited. If you
receive this in error, please contact the sender and delete the
material from any computer.
For Translation:
http://www.baxter.com/email_disclaimer
What's "Image", panning?
rEalm
"Aaron Eppolito" <synthesis77@...m>
01/23/2004 09:37 AM
Please respond to xl7
        To:     xl7@yahoogroups.com
        cc:
        Subject:        Re: [xl7] Re: world rom / copy cords
follow this layout.
-Aaron
Do you Yahoo!?
Yahoo! Groups Links
For Translation:
