trying to make the XL control my external gear - could use some help!!!!!!
2004-01-15 by dwoodaman
I have been going crazy trying to make what I think is a simple thing work with my XL7 and my external synths: dump a std midi file into the XL7 and have the midi file control the external synths as well as the internal XL7 sounds. I dump the file using E-loader into the XL and the XL stuff works perfectly as I would expect. The external devices will stop and start from the controls on the XL7, but they only play the internal patterns (with their limited sequencing abilities) not the midi information the XL should be feeding them with. The external devices are a Yamaha DX200, and EA1 and an ER1. They are chained like this: Midi out A from the XL to midi in on the EA1, midi thru on the EA1 to midi in on ER1, midi thru on ER1 to midi in on DX200. All the external devices are set to have their midi clock information externally (from the XL7). EA1 midi ch 11 and midi ch 12 ER1 midi ch 13 Yamaha DX200 midi channel 14,15,16 I have a std midi type 1 file, where the XL7 is on tracks 1-10, the EA1 on ch 11 and 12, ER1 on ch13 and DX200 on ch 14 In pattern edit, in channel assign, I have the tracks set up like this: T1 set to internal on ch1A T2 set to internal on ch2A And so on thru T1 ch10 for the XL. T11 set to external on ch11A T12 set to external on ch12A T13 set to external on ch13A T14 set to external on ch14A T15 set to external on ch15A T16 set to external on ch16A Why wont this work? One last thing to note, whenever I save the pattern, it messes with the preset that is called up on the EA1 and ER1 (not the DX200). I know that the pattern will hold that information, but I don't know how much room I need to leave at the beginning of any track so I can input this information is one tick enough? Won't this mess up the timing of the sequence? But that is really secondary, because it makes no difference if I can't use the full sequencing power of the XL for my external stuff. Any help GREATLY appreciated. Dana
