Error Code 100
Error Code 100
2004-01-31 by jdou1901
When I turn my Xl-7 on, I get this message- Error! Code 100. Save
Failed. I'm using OS 1.31. The last time I used the unit and it
booted up without this message, I set my tempo to ext to slave to my
computer. Now, when I turn on and get this error, my tempo is still
set to ext(this has not happened before). When I go to midi function
to reset tempo, I get a message - Compact Data Now--press Enter. I
hit midi button again and this goes away with a message that says,
Compact Data Soon. Then the unit works fine. But this happens each
time I turn on the unit. Anyone know what this means?
Re: [xl7] Error Code 100
2004-01-31 by Aaron Eppolito
--- jdou1901 <jdouglas@...> wrote:
> I get a message - Compact Data Now--press Enter. I hit midi
> Compact Data Soon. Anyone know what this means?
It means exactly what it says.  You need to press Enter when it wants
you to.  Since you didn't press Enter, it's telling you that you need
to let it compact soon.
Press Enter the next time it asks.
-Aaron
PS. in case you're wondering, after time, flash memory gets fragmented
just like a hard drive.  you're now at the point where there's no free
space and it needs to defragment (compact).
Do you Yahoo!?
Yahoo! SiteBuilder - Free web site building tool. Try it!
http://webhosting.yahoo.com/ps/sb/
RE: [xl7] Error Code 100
2004-02-02 by Jody Douglas
Thanks for the response, I will do it.
Sent: Saturday, January 31, 2004 2:54 PM
To: xl7@yahoogroups.com
-Aaron
Do you Yahoo!?
Yahoo! Groups Links
To visit your group on the web, go to:
 http://groups.yahoo.com/group/xl7/
Your use of Yahoo! Groups is subject to:
 http://docs.yahoo.com/info/terms/
Re: Error Code 100
2004-02-03 by sincultura13
Aaron Said:
"PS. in case you're wondering, after time, flash memory gets
fragmented
space and it needs to defragment (compact)."
BTW, where exactly is this flash memory located? I seem to remember
when I was installing the expansion roms that only the original Xl-7
rom said 2mb flash... Is it there where the memory is at or is
elsewhere on the machine? Just curious....
thanks in advance...
Re: [xl7] Re: Error Code 100
2004-02-03 by Aaron Eppolito
There's several flash parts lurking around in your XL-7.  You could
have 2MB on each sound ROM (or it could be a 2MB ROM to hold presets),
you could have a whole 32MB flash ROM (which actually has 34MB,
[32+2]), but the flash part you're referring to is on the main board.
It is 16MB and holds the boot loader, the main OS, two copies of all
your settings, patterns, songs, and then has "room to grow".  It is
this room to grow that must get flushed back.
That was probably more info than you wanted...
-Aaron
> remember when I was installing the expansion roms that only the
> original Xl-7 rom said 2mb flash... Is it there where the memory
> is at or is elsewhere on the machine? Just curious....
Do you Yahoo!?
