Changing Patterns at ER1
2004-02-01 by midinovelarg
Anybody knows if i can change the patterns at Korg ER1 with my XX7? Thanx midinovela@...
2004-02-02 by dwoodaman
Yep and its been gone over here, basic thing is to set the midi to ext for the er1 channel, then insert a program event at the first tick in the pattern, make sure the m=0 and l=32 and also make the program change number 1 number less than you really want. Sorry this is short I am beat you can get better answers by searching on program change in the forum. Dana --- In xl7@yahoogroups.com, "midinovelarg" <trabantmusic@h...> wrote:
> Anybody knows if i can change the patterns at Korg ER1 with my XX7? > Thanx > midinovela@h...
2004-02-02 by Turby Schmidt
Thanx, i just checked it and program change seems to work, but the electribe is not changing the patterns directly, it changes after completing the current pattern, so it seems to be necesary to send the program change information befor the change occurs [sorry im not a native speaker], but this way i cant loop this pattern with the program change information. So what can i do? create a once played pattern including this program change information? Any other suggestions? Turby >From: "dwoodaman" <dwoodaman@...> >Yep and its been gone over here, basic thing is to set the midi to >ext for the er1 channel, then insert a program event at the first >tick in the pattern, make sure the m=0 and l=32 and also make the >program change number 1 number less than you really want. >Sorry this is short I am beat you can get better answers by searching >on program change in the forum. >Dana >--- "midinovelarg" <trabantmusic@h...> wrote: > > Anybody knows if i can change the patterns at Korg ER1 with my XX7? _________________________________________________________________ The new MSN 8: smart spam protection and 2 months FREE* http://join.msn.com/?page=features/junkmail
2004-02-03 by dwoodaman
The best way is to wipe the patterns on the ER1 and use a pattern in the XL7. I quote here from someone on this group WAY smarter than I am - whose name I lost! sorry! - who turned me onto this: " Actually Dana I have to step in and tell you that you're 100% wrong. I am an ER-1 owner so listen up ;). Set sync to external on the ER-1 and set the midi channel of your choice. Configure the appropriate track on the XX-7 to external only same midi channel. Press the Midi button (last function button in ER-1) and scroll down to filter . Make sure you turn all filtering off so the display blinks like this " - - - " . This disable Program changes etc etc . <- I didn't do this part. Now program a set of percussion sounds (small kit in the ER-1) DO NOT STEP PROGRAM ANYTHING ON THE ER-1 !!!!!!! Set the XX-7 into grid mode and assign the pads on the ER-1 to corresponding Midi note numbers of keys with an octave keyspan. The ER-1 can be programmed in realtime ,step and grid modes via the XX-7 with full velocity control ,all the swing, scale and clock offset options of the sequencer in the XX-7 apply. The ER-1 sequencer will light up the > (play button). However it's tempo will be locked to the XX-7 and all note data will be received from the XX-7 as nothing is stored on the corresponding ER-1 pattern other than tempo sync delay and the sounds themselves. You can set the ER-1 to respond under midi filter to Program Change messages and have a swag of programmed kits without any pattern data stored in the ER-1 for recall and full dynamic sequencing on the XX- 7. Lastly - the only limitation you will have is Motion sequencing. The XX-7's do no recognize NRPN's and therefore realtime knob tweeks cannot be recorded into the XX-7's sequencer. However if you hit record and play on the ER-1 empty pattern and tweek the knobs then store. The Motion sequencers will be store in the pattern and the XX-7 can do all the other work for you with all those time signature features you want. Trust ME it DOES WORK !!!!!!!!!" And yeah it does work. D --- In xl7@yahoogroups.com, "Turby Schmidt" <trabantmusic@h...> wrote: > > Thanx, > i just checked it and program change seems to work, but > the electribe is not changing the patterns directly, it changes after > completing the current pattern, so it seems to be necesary to send the > program change information befor the change occurs [sorry im not a native > speaker], but this way i cant loop this pattern with the program change > information. > So what can i do? create a once played pattern including this program change > information? > Any other suggestions? > Turby > > >From: "dwoodaman" <dwoodaman@y...> > > >Yep and its been gone over here, basic thing is to set the midi to > >ext for the er1 channel, then insert a program event at the first > >tick in the pattern, make sure the m=0 and l=32 and also make the > >program change number 1 number less than you really want. > >Sorry this is short I am beat you can get better answers by searching > >on program change in the forum. > >Dana > >--- "midinovelarg" <trabantmusic@h...> wrote: > > > Anybody knows if i can change the patterns at Korg ER1 with my XX7?
> > _________________________________________________________________ > The new MSN 8: smart spam protection and 2 months FREE* > http://join.msn.com/?page=features/junkmail
2004-02-03 by Oscar Finch
--- On Mon 02/02, dwoodaman < dwoodaman@... > wrote: Actually taht would have been ME :D
From: dwoodaman [mailto: dwoodaman@...]To: xl7@yahoogroups.comDate: Tue, 03 Feb 2004 04:30:57 -0000Subject: [xl7] Re: Changing Patterns at ER1The best way is to wipe the patterns on the ER1 and use a pattern in the XL7. I quote here from someone on this group WAY smarter than I am - whose name I lost! sorry! - who turned me onto this:"Actually Dana I have to step in and tell you that you're 100% wrong. I am an ER-1 owner so listen up ;).Set sync to external on the ER-1 and set the midi channel of your choice.Configure the appropriate track on the XX-7 to external only same midi channel.Press the Midi button (last function button in ER-1) and scroll down to filter . Make sure you turn all filtering off so the display blinks like this " - - - " . This disable Program changes etc etc . <-I didn't do this part.Now program a set of percussion sounds (small kit in the ER-1)DO NOT STEP PROGRAM ANYTHING ON THE ER-1 !!!!!!!Set the XX-7 into grid mode and assign the pads on the ER-1 to corresponding Midi note numbers of keys with an octave keyspan. The ER-1 can be programmed in realtime ,step and grid modes via the XX-7 with full velocity control ,all the swing, scale and clock offset options of the sequencer in the XX-7 apply.The ER-1 sequencer will light up the > (play button). However it's tempo will be locked to the XX-7 and all note data will be received from the XX-7 as nothing is stored on the corresponding ER-1 pattern other than tempo sync delay and the sounds themselves. You can set the ER-1 to respond under midi filter to Program Change messages and have a swag of programmed kits without any pattern data stored in the ER-1 for recall and full dynamic sequencing on the XX-7. Lastly - the only limitation you will have is Motion sequencing. The XX-7's do no recognize NRPN's and therefore realtime knob tweeks cannot be recorded into the XX-7's sequencer.However if you hit record and play on the ER-1 empty pattern and tweek the knobs then store. The Motion sequencers will be store in the pattern and the XX-7 can do all the other work for you with all those time signature features you want.Trust ME it DOES WORK !!!!!!!!!"And yeah it does work.D--- In xl7@yahoogroups.com, "Turby Schmidt" wrote:> > Thanx,> i just checked it and program change seems to work, but> the electribe is not changing the patterns directly, it changes after > completing the current pattern, so it seems to be necesary to send the > program change information befor the change occurs [sorry im not a native > speaker], but this way i cant loop this pattern with the program change > information.> So what can i do? create a once played pattern including this program change > information?> Any other suggestions?> Turby> > >From: "dwoodaman" > > >Yep and its been gone over here, basic thing is to set the midi to> >ext for the er1 channel, then insert a program event at the first> >tick in the pattern, make sure the m=0 and l=32 and also make the> >program change number 1 number less than you really want.> >Sorry this is short I am beat you can get better answers by searching> >on program change in the forum.> >Dana> >--- "midinovelarg" wrote:> > > Anybody knows if i can change the patterns at Korg ER1 with my XX7?> > _________________________________________________________________> The new MSN 8: smart spam protection and 2 months FREE* > http://join.msn.com/?page=features/junkmail Yahoo! Groups Links To visit your group on the web, go to:http://groups.yahoo.com/group/xl7/ To unsubscribe from this group, send an email to:xl7-unsubscribe@yahoogroups.com Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. _______________________________________________ Join Excite! - http://www.excite.com The most personalized portal on the Web! [Non-text portions of this message have been removed]
