Cubase SX / XL-7 midi woes
2004-02-17 by Justin Grimley
I am having some serious problems using the XL-7 as my pattern
sequencer hooked up to Cubase and was hoping someone might have an
idea of what is going on (sorry for the long post).
First off I will recap my setup as outlined in a previous post:
In Cubase I have a template with 12 midi tracks which map to tracks 5-
16 from the XL-7. I am using the input transformer on the tracks in
Cubase so that they filter out channels not assigned for this track.
(I'm using a Steinberg Midex8 midi interface.)
For example:
In cubase:
Midi Track 1 -> Halion channel 1 <- From XL-7 channel 5
Midi Track 2 -> Halion channel 2 <- From XL-7 channel 6
Midi Track 3 -> Halion channel 3 <- From XL-7 channel 7
Midi Track 4 -> Halion channel 4 <- From XL-7 channel 8
Midi Track 5 -> Virusb channel 1 <- From XL-7 channel 9
Midi Track 6 -> Virusb channel 2 <- From XL-7 channel 10
Midi Track 7 -> Virusb channel 3 <- From XL-7 channel 11
Midi Track 8 -> Virusb channel 4 <- From XL-7 channel 12
Midi Track 9 -> MS2000r channel 1 <- From XL-7 channel 13
Midi Track 10 -> EX5 channel 1    <- From XL-7 channel 14
Midi Track 11 -> Juno 106 channel 1 <- From XL-7 channel 15
Midi Track 12 -> Absynth2 channel 1 <- From XL-7 channel 16
Each track in the XL-7 template is storing a CC#11 controller as the
first event so that when I save the template the channel routings are
stored.
In the Cubase midi preferences dialog, I filter out CC##11.  I also
filter program changes and SYSEX for both thru and record.
Every time I use this setup, 2 problems occur at intermittent times,
and with no obvious pattern of events:
[1] ... The Access Virus b will not make any sound.  Even doing a
patch audition by pressing EDIT & SYNC or choosing any other patch,
will not result in sound.  The virus has to be completely shut down
and restarted.
[2] ... The XL-7 will completely lock-up and has to be
restarted.  "Local" is on in the XL-7 because I use the pads to
transmit midi to my other devices as well as internal patches.  No
tracks in Cubase are being routed back to the XL-7 so there shouldn't
be a midi loopback problem.  The only thing that I can see that the
XL-7 receives from Cubase is midi clock and song pointer info.
Anything else I should look at?
Thanks for listening,
grimley
Re: [xl7] Cubase SX / XL-7 midi woes
2004-02-17 by erik_magrini@Baxter.com
Hmmm, no idea what could be causing this one.  You're recording while in
loop mode in SX right?  What do you have your knobs on the Virus set to
send, CC's or sysex?
rEalm
"Justin Grimley" <grimley@...>
02/17/2004 12:24 AM
Please respond to xl7
        To:     xl7@yahoogroups.com
        cc:
        Subject:        [xl7] Cubase SX / XL-7 midi woes
For example:
In cubase:
stored.
and restarted.
grimley
Yahoo! Groups Links
The information transmitted is intended only for the person(s)or entity
to which it is addressed and may contain confidential and/or legally
privileged material. Delivery of this message to any person other than
the intended recipient(s) is not intended in any way to waive privilege
or confidentiality. Any review, retransmission, dissemination or other
use of, or taking of any action in reliance upon, this information by
entities other than the intended recipient is prohibited. If you
receive this in error, please contact the sender and delete the
material from any computer.
For Translation:
http://www.baxter.com/email_disclaimer
Re: Cubase SX / XL-7 midi woes
2004-02-18 by Justin Grimley
rAlm,
Where do I check that?
In the control menu I can select Midi Control Lo and Hi page.  I have
it set to LoPage -> Contr and HiPage -> SysEx.  I believe these are
the settings I need for Emagic SoundDiver.
-grimley
while in
set to
> rEalm
> "Justin Grimley" <grimley@i...>
> 02/17/2004 12:24 AM
>         cc:
5-
track.
> For example:
> In cubase:
are
> stored.
times,
> and restarted.
shouldn't
> grimley
entity
legally
than
privilege
other
by
> For Translation:
Re: [xl7] Re: Cubase SX / XL-7 midi woes
2004-02-19 by erik_magrini@Baxter.com
Actually for Sounddiver they both need to be set to sysex.  But it looks
like you have them set right for what I was thinking, no other ideas what
could be causing that problem.
rEalm
rAlm,
-grimley
For Translation:
2004-02-19 by Justin Grimley
Thanks for trying anyway!
This evening I'm going to try hooking up a midi merge box to the XL-7
and split the output so that it goes to both Cubase and the Virus.
Same with the Midex to Virus connection.  That way I can bypass
Cubase and see if it is a XL-7->Virus issue or a XL7-Cubase->Virus
issue.
-Justin.
looks
ideas what
> rEalm
> rAlm,
have
> -grimley
entity
legally
than
privilege
other
by
> For Translation:
Good idea.
rEalm
02/19/2004 01:04 PM
        cc:
        Subject:        [xl7] Re: Cubase SX / XL-7 midi woes
issue.
-Justin.
looks
ideas what
> rEalm
> rAlm,
have
> -grimley
entity
legally
than
privilege
other
by
> For Translation:
Yahoo! Groups Links
For Translation:
Re: XL-7 midi woes - Aaron??
2004-03-06 by Justin Grimley
Aaron,
Do you have any idea what could be going on here?
I have narrowed the problem down by disconnecting the Virus midi in
from my midi patchbay altogether (midex 8).
I now have the XL-7 midi B connected to the Virus midi in and I am
still seeing the problem.  I was convinced this was a Cubase problem.
Anyway, playing back a pettern on the XL-7 (just one track output to
channel:01B and Dest:both going to Virus) the sound on the Virus will
stop.  Preview sound on the Virus will not work (hold Edit and Sync),
playing the pads on the XL-7 will make no sounds on the Virus.
Previously I had to reset the Virus to fix the problem.  Changing
presets would have no affect.  However, I just discovered that if I
change from multi to single mode and back on the Virus then the
problem is cleared and all is good .... until I start play again on
the XL-7.
I would greatly appreciate any help on this.
-Justin.
> Good idea.
> rEalm
> 02/19/2004 01:04 PM
>         cc:
7
> issue.
> -Justin.
it
> looks
> ideas what
> > rEalm
> > rAlm,
> have
are
> > -grimley
For example:
In cubase:
stored.
and restarted.
grimley
> entity
> legally
> than
> privilege
> other
information
> by
> > For Translation:
entity
legally
than
privilege
other
by
> For Translation:
RE: [xl7] Re: XL-7 midi woes - Aaron??
2004-03-06 by Matt Picone
Hi Justin
How about changing presets without leaving multi mode? Does that fix
anything?
Have you ruled out all stray midi messages by doing an ERASE ALL
CONTROLLERS on the track?
-m@
> From: Justin Grimley [mailto:grimley@...]
> Sent: Saturday, March 06, 2004 2:13 PM
> Subject: [xl7] Re: XL-7 midi woes - Aaron??
> Aaron,
> the XL-7.
> -Justin.
> > Good idea.
> > rEalm
> > 02/19/2004 01:04 PM
> >         cc:
> 7
> > issue.
> > -Justin.
> it
> > looks
> > ideas what
> > > rEalm
> > > rAlm,
> > have
> are
> > > -grimley
> pattern sequencer hooked up to Cubase and was hoping someone
> might have an idea of what is going on (sorry for the long post).
> tracks 5- 16 from the XL-7. I am using the input transformer
> on the tracks in Cubase so that they filter out channels not
> assigned for this track. (I'm using a Steinberg Midex8 midi
> interface.)
> For example:
> In cubase:
> as the first event so that when I save the template the
> channel routings are stored. In the Cubase midi preferences
> dialog, I filter out CC##11. I also filter program changes
> times, and with no obvious pattern of events:
> doing a patch audition by pressing EDIT & SYNC or choosing
> any other patch, will not result in sound. The virus has to
> be completely shut down and restarted.
> to transmit midi to my other devices as well as internal
> patches. No tracks in Cubase are being routed back to the
> XL-7 so there shouldn't be a midi loopback problem. The only
> thing that I can see that the XL-7 receives from Cubase is
> grimley
> > entity
> > legally
> > than
> > privilege
> > other
> information
> > by
> > > For Translation:
> > Yahoo! Groups Links
> entity
> legally
> than
> privilege
> other
> by
> > For Translation:
Matt,
Changing presets without leaving mult-mode does not fix it.  I have
to switch to single mode and back to multi.
As for the stray midi messages.  This is what I originally thought
was happening as I have a CC#11 at the start of every track on my
default empty pattern.  This is so that the pattern retains it's
channel routings when I store it.  However, erasing the tracks
(holding erase and track number) still does not fix the problem.
I appreciate you trying though.
-Justin
--- In xl7@yahoogroups.com, "Matt Picone" <matman@m...> wrote:
> Hi Justin
> anything?
> -m@
> > From: Justin Grimley [mailto:grimley@i...]
> > Aaron,
in
am
problem.
to
will
Sync),
I
on
> > the XL-7.
> > -Justin.
> > > Good idea.
> > > rEalm
> > > 02/19/2004 01:04 PM
> > >         cc:
the XL-
> > 7
Virus.
>Virus
> > > issue.
> > > -Justin.
But
> > it
> > > looks
> > > ideas what
> > > > rEalm
> > > > rAlm,
page.  I
> > > have
these
> > are
> > > > -grimley
> > interface.)
> > For example:
> > In cubase:
> > grimley
or
> > > entity
> > > legally
other
> > > than
> > > privilege
or
> > > other
> > information
> > > by
you
> > > > For Translation:
> > > Yahoo! Groups Links
> > entity
> > legally
other
> > than
> > privilege
> > other
information
> > by
> > > For Translation:
> > Yahoo! Groups Links
Re: [xl7] Re: XL-7 midi woes - Aaron??
2004-03-06 by Aaron Eppolito
--- Justin Grimley <grimley@...> wrote:
> Aaron,
Not really, but I'll take a guess.
Perhaps the Virus is unhappy with a reset all controllers message?  I'd
plug the output B of your XL-7 into a computer and run a program called
SendSX to see the bytes coming out of the XL-7.  You could even send
them from there to the Virus if you wanted.  You might be able to
figure out the offending message and let us know.
-Aaron
Do you Yahoo!?
Yahoo! Search - Find what you\ufffdre looking for faster
http://search.yahoo.com
Thanks Aaron ... I'm feeling pretty stupid right now!
So I was sending volume change 0 to the Virus.
On the XL-7 I had set the volume for tracks 9-12 (mapped to virus) to
zero because I didn't want the internal sounds on the XL-7 playing
for those tracks.  Changing the volume for those tracks to 127 fixed
the virus problem .... doh!
Anyway, now my problem is this:
I have tracks 9-12 (virus) channel assign set to Dest:both because I
want to use the XL-7 arp to trigger the virus, but I don't want the
XL7 sounds to be heard on those tracks.  What is the workaround for
this situation?
Justin.
--- In xl7@yahoogroups.com, Aaron Eppolito <synthesis77@y...> wrote:
> --- Justin Grimley <grimley@i...> wrote:
> > Aaron,
to
will
Sync),
I'd
called
> -Aaron
> Do you Yahoo!?
> Yahoo! Search - Find what you're looking for faster
> this situation?
Route them to the sub outs and don't mute/disconnect these?
-m@
2004-03-07 by Justin Grimley
Matt,
You're a star!
After I figured out I needed to connect a cable to the back of the
box to enable the sub outs, I was flying.
Justin.
because I
for
> > this situation?
> -m@
2004-03-07 by Matt Picone
> Matt,
> You're a star!
> Cheers,
> Justin.
No Justin, for making music, you're the star.
In this case, I'm just the assistant.
-m@
2004-03-07 by Aaron Eppolito
Not to rain on Matt's parade, but an even easier workaround is to make
a "blank" user preset (i.e. one with all four instruments "none").  Put
that preset on the channels you want to be silent.
If you're feeling frisky, you can even make custom "external arp"
presets like this.  Simply assign none to all the instruments, assign
an arp you like, then save the preset.  Now when you call up that
preset on an "both" track, you won't hear any internal sound but you'll
get the arp you assigned played on your Virus.
-Aaron
>> -m@
>>> because I want to use the XL-7 arp to trigger the virus, but
>>> I don't want the XL7 sounds to be heard on those tracks.
Do you Yahoo!?
Yahoo! Finance: Get your refund fast by filing online.
http://taxes.yahoo.com/filing.html
2004-03-07 by Turby Schmidt
>-m@
Does the earase all controllers funcion also erase sysex data [in my case
from Korg ER1] ?
Turby
MSN 8 helps eliminate e-mail viruses. Get 2 months FREE*.
http://join.msn.com/?page=features/virus
TnT: Aaron's cool external only arp tip
2004-03-07 by steve_the_composer
Cool tip, Aaron. I am presently learning the sequencer, so please
share other cool sequencer tips you may have (above and beyond the
ordinary).  Thanks.
[snip]
> assign an arp you like, then save the preset.  Now when you call up
> that preset on an "both" track, you won't hear any internal sound
> but you'll get the arp you assigned played on your Virus.
> -Aaron
