Nice one, I'm going to add that to the Tips and tricks doc.
rEalm
I too was having problems with my SPDIF output. In fact it did not
work at all. It was a grounding issue. Here is how I fixed it.
for this fix you will need: about 4 inches of speaker wire. a
screwdriver. about ten minutes.
1. open the case up like you would to replace a ROM
2. wrap some of the bare speaker wire around one of the chassis
screws, between the two case panels (a wire sandwich)
3. reassemble the unit
4. take the (bare) loose end of the wire and wrap it around the
SPDIF jack
5. plug in your spdif cable tight enough that it holds this wire on.
(you could probably solder it with no concern)
6.you're done
I havent had so much as a hiccup since doing this.
You must ground the wire to the Chassis, the various screws on the
back face of the unit did not work for me.
Yahoo! Groups Links
The information transmitted is intended only for the person(s)or entity
to which it is addressed and may contain confidential and/or legally
privileged material. Delivery of this message to any person other than
the intended recipient(s) is not intended in any way to waive privilege
or confidentiality. Any review, retransmission, dissemination or other
use of, or taking of any action in reliance upon, this information by
entities other than the intended recipient is prohibited. If you
receive this in error, please contact the sender and delete the
material from any computer.
For Translation:
http://www.baxter.com/email_disclaimer
