Re: [xl7] Re: External tempo/MidiMerge
2004-03-19 by Christoph Kluxen
I have a similiar question, which Midi Mege boxes haven´´t problems sending
Midi Clock sync??
The Phil Rees Box I used till now seems to make serious problems.
Thanx,
Christoph
thanks for the help. i think i'm narrowing in on the problem. i don't have
another durm machine to test, but i am getting rock-solid sync with my other
synths for thier delays and LFO's, all hooked into the same MOTU interface.
so i think Digital Performer is not the problem. gotta be the cables,
interface,
or XL-7 (which i highly doubt.)
realm, i took your suggestion and tried swapping MIDI cables. unfortunately,
it's the same brand of super cheapo cables, but a shorter length so i
thought:
give it a try. the sync has actually improved a bit.  i'm not 100% about my
judgement now, since i've been obsessed with this problem for a couple of
weeks. so i went ahead and ordered a top of the line MIDI cable to see if
that
helps. i once had a problem with cheap MIDI cables and my Nord modular a
few years ago (which i had forgotten about until you reminded me.)
you asked if i was going by the front panel display to verify tempo sync -
yes
and no.  when i hear a fluctuation in delays or LFO's during playback, i'll
look
at the panel and see that it has jumped to a signifigantly different tempo
(though briefly.) the typical fluctuations are small - 1or 2 BPM's, and i
don't
hear anything wrong with those, so you're right that those must be normal.
it's
the big stuff that screws everything up, but they don't last long.
if the new MIDI cable doesn't solve this, then i will probably try a new
interface. did you mention you used a MIDISport, realm? anything else that
anyone recommends? it's needs to be USB and Mac compatible.
thanks so much!
--- In xl7@yahoogroups.com, erik_magrini@B... wrote:
> That's a good idea too, I use that one sometimes for trouble shooting.  If
> you're syncing to another box, make sure it's tempo is set to a whole
> number, as the XX-7's don't display finer resolutions, and the display
> will always jump around in these cases.
> ...i would first find a drum machine, or kbd with midi clock out and
> try syncing with that....at least you could then eliminate the xl7 as
> being the problem.
Yahoo! Groups Links
*	To visit your group on the web, go to:
http://groups.yahoo.com/group/xl7/
*	To unsubscribe from this group, send an email to:
*	Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service.
+++ NEU bei GMX und erstmalig in Deutschland: TÜV-geprüfter Virenschutz +++
100% Virenerkennung nach Wildlist. Infos: http://www.gmx.net/virenschutz
