Need quick help, gonna throw my MP7 to a wall! also problems with e-loader
2004-03-26 by r3gu
2004-03-26 by r3gu
Shit, i just installed new ROMs and now my MP7 is freakin up. if i save patterns, it does not save all the instruments as it has this far.. actually, when i turn my MP7 off, it replaces the first 2 channels (1&2) with 111(0) prc:Kix 2/ MP7 ROM (channel 1) and 114(0) prc:Snares 3/ User sounds (channel 2) why does it do like this? it has messed my every pattern. Also i'm havin problems with E-loader 1.1. i'm using Windows 2000 and edirol um-1 usbmidi port, when i try to save my pattern, it tries to save, but then informs that "saving of file "xx" failed"? why this also? NEED HELP FAST!
2004-03-26 by r3gu
Ok, i can work around that by not using the first 2 channels, but it still sucks.. whatäs wring with e-loader? are they gonna make new versions of it? > > Also i'm havin problems with E-loader 1.1. i'm using Windows 2000 and > edirol um-1 usbmidi port, when i try to save my pattern, it tries to
> save, but then informs that "saving of file "xx" failed"? > why this also? > > > > NEED HELP FAST!
2004-03-27 by wayne parch
I wish that I could help...I am like 3 months into having this machine...I am no novice at all...also I have a xl7....so it's the same as yours but not exact...sorry bro... r3gu <clubfeel@...> wrote:Ok, i can work around that by not using the first 2 channels, but it still sucks.. what�s wring with e-loader? are they gonna make new versions of it? > > Also i'm havin problems with E-loader 1.1. i'm using Windows 2000 and > edirol um-1 usbmidi port, when i try to save my pattern, it tries to > save, but then informs that "saving of file "xx" failed"? > why this also? > > > > NEED HELP FAST! Yahoo! Groups SponsorADVERTISEMENT --------------------------------- Yahoo! Groups Links To visit your group on the web, go to: http://groups.yahoo.com/group/xl7/ To unsubscribe from this group, send an email to: xl7-unsubscribe@yahoogroups.com Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. Do you Yahoo!? Yahoo! Mail - More reliable, more storage, less spam [Non-text portions of this message have been removed]
2004-03-27 by dj 61
Maybe you should try connecting directly with usb for eloader. I had
problems with my midi-sport at first, but then it started working.
I'm not sure why, but as long as it works...
As for your problem with the presets:
Do you have data on those channels? CC or note info?
Try saving your global settings next time and see if that will
help things.
Tom
2
(0)
and
2004-03-27 by r3gu
Ok, i'll have to find a bit longer usb-cable.. This gets even weirder.. first, i searched the right instruments for 1 of my patterns that have been messed for the 2 channels, saved that and then saved global setup... after i put the mp7 back on, all the patterns had replaced fisrt 2 channels with those instrumetns i just put on fixed patterns... it's note info.
> As for your problem with the presets: > Do you have data on those channels? CC or note info? > Try saving your global settings next time and see if that will
2004-03-28 by dj 61
If you do not have notes or controller data on those tracks, that behavior is normal. If not you may want to shout at Aaron the resident expert! --- In xl7@yahoogroups.com, "r3gu" <clubfeel@s...> wrote: > Ok, i'll have to find a bit longer usb-cable.. > > This gets even weirder.. first, i searched the right instruments for > 1 of my patterns that have been messed for the 2 channels, saved that > and then saved global setup... after i put the mp7 back on, all the > patterns had replaced fisrt 2 channels with those instrumetns i just
> put on fixed patterns... it's note info. > > > As for your problem with the presets: > > Do you have data on those channels? CC or note info? > > Try saving your global settings next time and see if that will
2004-03-28 by r3gu
YES!! for some reason, i had turned off the "receive program change" for those 2 first channels, back on and every pattern have their own instruments again! YIPPEEE! BTW, to get at e-loader, where can i find the usb-drivers, didn't find them at www.e-mu.com?
2004-03-28 by n6i6s6
I am willing to bet I know the problem, then. You have either an Edirol or Roland controller with V-link enabled. Let me know if this is right. --- In xl7@yahoogroups.com, "r3gu" <clubfeel@s...> wrote:
> YES!! > for some reason, i had turned off the "receive program change" for > those 2 first channels, back on and every pattern have their own > instruments again! YIPPEEE! > > BTW, to get at e-loader, where can i find the usb-drivers, didn't > find them at www.e-mu.com?
2004-03-29 by erik_magrini@Baxter.com
Shit, i just installed new ROMs and now my MP7 is freakin up. if i save patterns, it does not save all the instruments as it has this far.. actually, when i turn my MP7 off, it replaces the first 2 channels (1&2) with 111(0) prc:Kix 2/ MP7 ROM (channel 1) and 114(0) prc:Snares 3/ User sounds (channel 2) >>>Everytime you power on the XX-7, it will revert to the last Multisetup you had loaded, NOT the last pattern. also, make sure you have Patch changes enabled on the MIDI Menu too. <<< Also i'm havin problems with E-loader 1.1. i'm using Windows 2000 and edirol um-1 usbmidi port, when i try to save my pattern, it tries to save, but then informs that "saving of file "xx" failed"? why this also? >>>>Sadly, this could be due to any number of things, but probably it caused by your midi port. There will be no update to E_Loader. <<< rEalm The information transmitted is intended only for the person(s)or entity to which it is addressed and may contain confidential and/or legally privileged material. Delivery of this message to any person other than the intended recipient(s) is not intended in any way to waive privilege or confidentiality. Any review, retransmission, dissemination or other use of , or taking of any action in reliance upon, this information by entities other than the intended recipient is prohibited. If you receive this in error, please contact the sender and delete the material from any computer. For Translation: http://www.baxter.com/email_disclaimer [Non-text portions of this message have been removed]
2004-04-01 by BEAUFILS Adrien
If you have the cd of E-loader you will found the usb drivers in the prog files when your E-loader is installed. I will try to send this files by mail but i am not a proffessionnal of the communication so send me a mail if you don't receive this n6i6s6 <n.scroggins@...> wrote: I am willing to bet I know the problem, then. You have either an Edirol or Roland controller with V-link enabled. Let me know if this is right. --- In xl7@yahoogroups.com, "r3gu" <clubfeel@s...> wrote: > YES!! > for some reason, i had turned off the "receive program change" for > those 2 first channels, back on and every pattern have their own > instruments again! YIPPEEE! > > BTW, to get at e-loader, where can i find the usb-drivers, didn't > find them at www.e-mu.com? --------------------------------- Yahoo! Groups Links To visit your group on the web, go to: http://groups.yahoo.com/group/xl7/ To unsubscribe from this group, send an email to: xl7-unsubscribe@yahoogroups.com Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. --------------------------------- Yahoo! Mail : votre e-mail personnel et gratuit qui vous suit partout ! Créez votre Yahoo! Mail Dialoguez en direct avec vos amis grâce à Yahoo! Messenger ! [Non-text portions of this message have been removed]
2004-04-01 by Chris
if you download the e-loader on www.emu.com (then support/software & manuals/hardware/command stations/ xx-7/ then select your OS/then right on top (if using windows)) the usb drivers are included.. i just dl'd the file 2 days ago..
From: BEAUFILS Adrien [mailto:fatalojyxvsfacial@...]
Sent: Donnerstag, 01. April 2004 14:34
To: xl7@yahoogroups.com
Subject: Re: [xl7] Re: Need quick help, gonna throw my MP7 to a wall!
WORKS again!!!!!!!!!!!
n6i6s6 <n.scroggins@comcast.net> wrote: I am willing to bet I know the
is right.
> YES!!
Yahoo! Groups Links
_____
Yahoo! Groups Links
* To visit your group on the web, go to:
* To unsubscribe from this group, send an email to:
xl7-unsubscribe@...m
<mailto:xl7-unsubscribe@yahoogroups.com?subject=Unsubscribe>
* Your use of Yahoo! Groups is subject to the Yahoo! Terms of
Service <http://docs.yahoo.com/info/terms/> .
