Grid recording question
2004-03-31 by gutman75
Hi all!
Yesterday I started playing with grid recording - lots of fun indeed,
not least because it's possible to switch tracks on the fly and keep
adding stuff. If I want to tweak a preset or adjust the mix, I can
pop out of recording mode without stopping - great. But then, how do
I return to grid recording? It seems that I have to stop the
sequencer, which kind of ruins the continuous flow of the process :-)
Re: Grid recording question
2004-03-31 by retbah
--- In xl7@yahoogroups.com, "gutman75" <bgutman@c...> wrote:
> Hi all!
indeed,
keep
how do
process :-)
HI
Just hold play  and press Rec...
> Hi all!
indeed,
keep
how do
process :-)
Just hold PLay and press Record....
Re: [xl7] Re: Grid recording question
2004-03-31 by Aaron Eppolito
retbah is correct.  Press & hold play and hit rec.  Also, just so you
know, you don't even have to leave record mode at all if you don't want
to.  You can go in and tweek a preset (and save it!) without even
punching out.  Then, just exiting the editing mode you're in will bring
you back to grid edit.
-Aaron
Do you Yahoo!?
Yahoo! Finance Tax Center - File online. File on time.
http://taxes.yahoo.com/filing.html
-Aaron
Do you Yahoo!?
2004-03-31 by erik_magrini@Baxter.com
Although it should be pointed out that the Quick Edit knobs will be
controlling either Gate Time or Velocity if you stay in Grid Record mode,
just a heads up.
rEalm
-Aaron
Do you Yahoo!?
Yahoo! Groups Links
The information transmitted is intended only for the person(s)or entity
to which it is addressed and may contain confidential and/or legally
privileged material. Delivery of this message to any person other than
the intended recipient(s) is not intended in any way to waive privilege
or confidentiality. Any review, retransmission, dissemination or other
use of, or taking of any action in reliance upon, this information by
entities other than the intended recipient is prohibited. If you
receive this in error, please contact the sender and delete the
material from any computer.
For Translation:
http://www.baxter.com/email_disclaimer
2004-04-01 by gutman75
mode
Yep, that's why I mentioned leaving recording mode - to tweak a
preset using the Quick Edit knobs, or to adjust the mix.
To all who replied - thanks for the tip!
cheers,
Boris.
RE: [xl7] Re: Grid recording question
2004-04-01 by Matt Picone
Is it possible to use a grid with a resolution finer than 1/16?
-m@
> From: gutman75 [mailto:bgutman@...]
> Sent: Thursday, April 01, 2004 10:59 AM
> To: xl7@yahoogroups.com
> Subject: [xl7] Re: Grid recording question
> mode
> cheers,
> Boris.
> Over 1 billion served! The most music videos on the web.
> Click to Watch now!
> http://us.click.yahoo.com/Xkrq7C/IARHAA/n1hLAA/pWZylB/TM
2004-04-01 by Aaron Eppolito
Sure.  Press the resolution button.  16ths, 32nds, 8th3, 16th3
Crap!  That's a bug on my part.  Those knobs should only do grid edit
things if grid edit is on the screen.  My bad!
-Aaron
Do you Yahoo!?
Yahoo! Small Business $15K Web Design Giveaway
http://promotions.yahoo.com/design_giveaway/
2004-04-01 by robotchas
edit
> -Aaron
Man, I love the Internet.
