Base Tempo set to EXT, but XL-7 doesn't sync (?)
2004-05-02 by d_mike_e
Hello C.S.G's (Command Station Guru), In the studio I would like to use the Command Station as a 6 part (1 out per part) rompler. I've set up a Pattern (panning, volume) and Global (routing etc.) for it. In the Midi menu I've set the Base Tempo to EXT, so it slaves to Cubase. The Tempo display (and actual tempo in the Base Tempo screen) doesn't change to the tempo set in Cubase. What's going on? Am I missing something here? Can you help me out? THX, Maik
2004-05-02 by Stu
Have you set up Cubase to send midi clock on the out connected to the XL-7? Stu
-----Original Message----- From: d_mike_e [mailto:d_jumpmaster@...] Sent: 02 May 2004 19:58 To: xl7@yahoogroups.com Subject: [xl7] Base Tempo set to EXT, but XL-7 doesn't sync (?) Hello C.S.G's (Command Station Guru), In the studio I would like to use the Command Station as a 6 part (1 out per part) rompler. I've set up a Pattern (panning, volume) and Global (routing etc.) for it. In the Midi menu I've set the Base Tempo to EXT, so it slaves to Cubase. The Tempo display (and actual tempo in the Base Tempo screen) doesn't change to the tempo set in Cubase. What's going on? Am I missing something here? Can you help me out? THX, Maik Yahoo! Groups Links
2004-05-03 by d_mike_e
OK, will check on that. Maik --- In xl7@yahoogroups.com, "Stu" <routerman@z...> wrote: > Have you set up Cubase to send midi clock on the out connected to the XL-7? > > Stu > > -----Original Message----- > From: d_mike_e [mailto:d_jumpmaster@y...] > Sent: 02 May 2004 19:58 > To: xl7@yahoogroups.com > Subject: [xl7] Base Tempo set to EXT, but XL-7 doesn't sync (?) > > > Hello C.S.G's (Command Station Guru), > > In the studio I would like to use the Command Station as a 6 part (1
> out per part) rompler. > > I've set up a Pattern (panning, volume) and Global (routing etc.) > for it. In the Midi menu I've set the Base Tempo to EXT, so it > slaves to Cubase. > > The Tempo display (and actual tempo in the Base Tempo screen) > doesn't change to the tempo set in Cubase. What's going on? Am I > missing something here? > > Can you help me out? > > THX, > Maik > > > > > > Yahoo! Groups Links
2004-05-03 by erik_magrini@Baxter.com
Make sure you go to the sync menu in Cubase, and set it to transmit "Midi
Clock" to the correct Midi port. The tempo display in the LED's (same
place you can see the pattern location, Current Channel, and Current
Pattern) should show the new tempo, though I'm not sure if the menu based
settings will.
rEalm
d_mike_e <d_jumpmaster@...>
05/02/2004 01:57 PM
Please respond to xl7
cc: Subject: [xl7] Base Tempo set to EXT, but XL-7 doesn't sync (?) Hello C.S.G's (Command Station Guru), In the studio I would like to use the Command Station as a 6 part (1 out per part) rompler. I've set up a Pattern (panning, volume) and Global (routing etc.) for it. In the Midi menu I've set the Base Tempo to EXT, so it slaves to Cubase. The Tempo display (and actual tempo in the Base Tempo screen) doesn't change to the tempo set in Cubase. What's going on? Am I missing something here? Can you help me out? THX, Maik Yahoo! Groups Links The information transmitted is intended only for the person(s)or entity to which it is addressed and may contain confidential and/or legally privileged material. Delivery of this message to any person other than the intended recipient(s) is not intended in any way to waive privilege or confidentiality. Any review, retransmission, dissemination or other use of , or taking of any action in reliance upon, this information by entities other than the intended recipient is prohibited. If you receive this in error, please contact the sender and delete the material from any computer. For Translation: http://www.baxter.com/email_disclaimer [Non-text portions of this message have been removed]
