midi trig again
midi trig again
2004-06-04 by Matt Picone
I really wish the xx-7 had the ability to trigger/queue patterns from
midi notes. Does any other sequencer in its class have this feature?
-m@
Re: midi trig again
2004-06-04 by robotchas
I'm not sure what other sequencers I would put in the same class as
the ComStat, but the Electribes can queue patterns via MIDI and the
Roland MC's have the RPS feature (trigger single track) but no MIDI
queueing. I'm not sure if the Akais can select patterns over MIDI but
they definitely don't do RPS; I don't believe the Yamahas will do
either. I'd double-check the RS7k and MPC manuals though.
from
> -m@
RE: [xl7] Re: midi trig again
2004-06-04 by Stu
With the Yamaha (rm1x) you can send song select commands and it will change
the pattern that's playing. If you have the 'quantise' set to 1, then it
will change at the end of the current bar.
Stu
|-----Original Message-----
|Sent: 04 June 2004 20:11
|To: xl7@yahoogroups.com
|Subject: [xl7] Re: midi trig again
|from
|> -m@
|Yahoo! Groups Links
