XL-7 Effect Sends Question
2001-09-08 by j.burger
hi there,
i´m testing the xl-7 for some days now & finally got used to emu´s weird (as opposed to roland or yamaha) effect-routings.
but there´s still one problem i couldn´t solve: the manual says you can control the effect-sends via midi but all the settings i´ve tried, didn´t work.
my setup is:
send 1 - main (i use a fx a on this one)
send 2 - sub 1
send 3 - sub 2
send 4 - main (i use a fx b on this one)
i tried to route knobs o & p to effect sends 1 & 4 (i don´t use arpeggiators) but it didn´t work.
general thoughts:
the overall quality of the xl-7 is really good, although i (like others in this group) still miss alot of things.
but the main advantage over it´s competitors is the incredible quality of the hardware, which imo is the best built piece of equipment since the mpc 60.
thanks,
j.
Re: XL-7 Effect Sends Question
2001-09-09 by dubtribe@imperialdub.com
--- In xl7@y..., "j.burger" <j.burger@p...> wrote:
> my setup is:
> send 2 - sub 1
> send 3 - sub 2
> i tried to route knobs o & p to effect sends 1 & 4 (i don´t use arpeggiat=
> general thoughts:
> the overall quality of the xl-7 is really good, although i (like others i=
> but the main advantage over it´s competitors is the incredible quality of=
 the hardware, which imo is the best built piece of equipment since the mpc =
60.
> thanks,
> j.
The manual is really of no help whatever regarding the effects is it?
i read that silly diagram (reprintied throughout the manual) over and
over and finally, through experimentation, figured out that the effects
are ultimately output bound.
so you assign a reverb to send 4 (routed to the mains) and a chorus to
send 1 (routed to the mains) and leave the other sends dry.
this way you get verb or chorus (or whatever you want) on the mains and
still have 2 dry output pairs for drums and other stuff.
i can see by your diagram that you have come to the same conclusion.
i think it's ultimately pretty weak that the effects are bound ot the
outputs.
i'd like to see the output of the effects be routable to whatever out
you want, and use a standard send and return feature to assign the
amount on whatever preset you want.
Akai effects work like this (like a traditional mixer) but the
sequencers aren;t anything like this one...
live, learn, suffer...
DSS
Re: [xl7] Re: XL-7 Effect Sends Question
2001-09-10 by j.burger
hi dss,
thanks for your emphatic words. but they still leave me alone with my
problem.
let\ufffds not moan about the dated & unsatisfying routing-concept of the proteus
family. critics & users all over the world did this for years & emu didn\ufffdt
change anything for the better. but maybe sean or scott could give me an
answer please.
the problem again:
i use the following routing:
send 1 - mains (fx a on this one)
send 2 - sub 1
send 3 - sub 3
send 4 - main (fx b on this one)
i tried to route knobs o & p - in quick edit - to send 1 & 2 but i can only
make one of them work at a time.
i really need the sub outs for drums & bass (no eqs on bord - as y\ufffdall
know), so i obviously can not use 2 fx & a dry out on main.therefore i would
like to control the sends via midi.
some other questions:
- have ensoniq asr-x programmers been involved in the development of these
units ?
- is the resonance fault ever gonna be repaired ?
- the glitches with pattern switching are most obvious in busy patterns.
apart from that they behave different, if you switch them via main sreen or
LED View Select Section. to me it doesn\ufffdt feel like os - problem, rather a
lack of processor - power/speed. what can you tell me about that ?
i greatly appreciate an answer.
taking the rough with the smooth,
j.
2001-09-11 by dubtribe@imperialdub.com
> the problem again:
> send 2 - sub 1
> send 3 - sub 3
J.
maybe i didn't completely understand your post...
i have the same needs i think (want effects on some outs, and need dry
outs as well, want to change this set up between patterns for various
effects, and presets.)
i sort of solved this problem quickly by dedicating my outs as aux
sends in the master effects section.
this way i get:
Pattern 001
Mains (Send 1): light verb
Sub 1 (Send 2): Dry (drums)
Sub 2 (Send 3): chorus (bass)
-     (Send 4): Delay
in pattern edit i no longer have control over what amount of effect
happens, but i do have the ability to send my Tracks to Send 1 and Send
4 as needed.
i save this setup as "demo setup 1"
and save the pattern.
move to pattern 002
i set up:
Mains (Send 1): flange
Sub 2 (Send 3): dry (bass)
-     (Send 4): Delay
save this as "Demo Setup 2"
now when i recall, i have my effect routing and output routing all
sorted out.
i don't really know why it works, again the manual wasn't helpful.
but it sure sems to solve my output and effect send issues
still, i agree that the effects would be cooler if there were some midi
control over them.
and i am GLAD i missed the proteus debates...
hope this is at all helpful.
DSS
2001-09-11 by j.burger
hi dss,
thank you again - that sounds interesting. but this time i think i didn\ufffdt
fully understand.
> this way i get:
> Pattern 001
> -     (Send 4): Delay
> 4 as needed.
but how do you get a dry signal to the mains? i need that because i
definitely use the 2 subs for kick, snare, hihats & bass (all panned l/r to
get 4 single outs) to add eq and make it suit the location. therefore i\ufffdve
got only 2 sends left - either 1 fx / 1 dry or 2 fx. i definitely cannot
send my chords & sequences to either of the sub outs because the eqs almost
never fit.
regarding the midi-control: i realize now there\ufffds no such option but maybe
there\ufffds a weird work-around somewhere ?
all the best,
j.
2001-09-12 by dubtribe@imperialdub.com
well sadly, i don't.
so i save the special effects that simply don't work on things coming
out the mains for Send-4 routed to the mains, and use only general and
subtle effects like reverb and chorus on Send-1.
it's not perfect, but the only thing left to do would be to re open the
tedious debate about the whole concept of the Proteus effects.
i am just very happy that i can change this routing between patterns so
the effects can change with them.
poping between patterns in a single song (performed live in pattern
mode) can also work to replace the lack of midi control over the
effects.
jus' thinkin'
and feelin' for ya.
DSS
