Re: [xl7] Digest Number 1271
2004-10-12 by Richard Stewart
I am wondering if anyone in the group can assist me with a problem I am having with my mp-7. I am trying to program the sounds from my P ROM1 into my computer program. I am using Logic Audio and would like to be able to access the sounds from within the program. Does anyone have any info what the midi bank select info would be for this. Any help would be greatly appreciated. I have already be successful with programming the standand user and MP-7 banks. Thanks, Richard --- xl7@yahoogroups.com wrote: > > ------------------------ Yahoo! Groups Sponsor > --------------------~--> > Make a clean sweep of pop-up ads. Yahoo! Companion > Toolbar. > Now with Pop-Up Blocker. Get it for free! > http://us.click.yahoo.com/L5YrjA/eSIIAA/yQLSAA/pWZylB/TM > --------------------------------------------------------------------~-> > > > There are 7 messages in this issue. > > Topics in this digest: > > 1. Re: Suggested Carrying Cases? > From: "beatmakerz" > <cREATEADISC@...> > 2. Re: pad problems. > From: "jaxlore" <jaxlore@...> > 3. Re: pad problems. > From: "jaxlore" <jaxlore@...> > 4. Re: pad problems. > From: "vibesart" <edmann@...> > 5. Re: Re: Suggested Carrying Cases? > From: Greg Waltzer > <egwaltzer@...> > 6. Re: Suggested Carrying Cases? > From: "vibesart" <edmann@...> > 7. FYI: XL-7 for sale on ebay... > From: "paristick" <paristick@...> > > > ________________________________________________________________________ > ________________________________________________________________________ > > Message: 1 > Date: Sun, 10 Oct 2004 20:25:57 -0000 > From: "beatmakerz" <cREATEADISC@...> > Subject: Re: Suggested Carrying Cases? > > > > Why not just buy one of the mp7 emu bags????? > > > --- In xl7@yahoogroups.com, "vibesart" <edmann@p...> > wrote: > > > > Recommendation based on my own experience: the > Rubbermaid (and > other) > > Tuff-Tote type plastic molded cases + some good > foam. Get the > > "hardware grade" type that you find in places like > Home Depot - they > > have a reinforced double layer lid - super tough > sculpted-molded > body. > > I have used this type of case for sensitive > electronics many times > > including flights all over Europe and the US - > never a problem - the > > cases cost about $20, and if for some reason your > gear does not fit > as > > expected - you can return it locally. The 2 that I > have here hold > the > > XL-7 perfectly - with about 3" on either side > which I stuff with > > modular blocks of 3" high quality rigid > case-foam. I also put > blocks > > of the foam above and below the XL7, and there is > room on the bottom > > for wires, etc. > > > > > > ________________________________________________________________________ > ________________________________________________________________________ > > Message: 2 > Date: Mon, 11 Oct 2004 01:24:47 -0000 > From: "jaxlore" <jaxlore@...> > Subject: Re: pad problems. > > > sorry i didnt reply to this earlier was down in boca > raton seeing the > pixies what a great show....when i say E pad i mean > the third pad from > the left and the sixth pad from the left both on the > bottom row. i > guess i was praying there might be some strange pad > velocity setting > or something. but i may have to bite the bullet and > send it somewhere > its weird the number 6 pad is working fine today but > alas the number 3 > pad still cuts out. > > --- In xl7@yahoogroups.com, Bruddah Max > <bruddahmax@c...> wrote: > > On 10/8/04 8:18 PM, "jaxlore" <jaxlore@h...> > wrote: > > > > > thanks for the last response guys. my next ? is > i got mine as a demo > > > unit and i am not sure i might have two bad > pads. the unit looks like > > > its in pristine condition, and no other problems > but the E pad clips > > > and the G pad is totally different sensitivity > then all the other > > > pads? Any ideas. > > > > pick up the XL, shake it like an Etch-a-Sketch, > and chant "work, > dammit!" > > over and over. hey, sometimes that works. > > > > i haven't tried pad surgery yet on an XX-7, so > perhaps someone who > has can > > comment. i assume you've already checked that the > connectors to the > mobo are > > solid. not that that would cause such a problem, > but i usually do > rule-out > > troubleshooting and that'd be something done early > in that process. > > > > when you say the E pad clips, what do you mean? > > -- > > Bruddah Max > > Lord of the Dance > > > > > > ________________________________________________________________________ > ________________________________________________________________________ > > Message: 3 > Date: Mon, 11 Oct 2004 01:26:32 -0000 > From: "jaxlore" <jaxlore@...> > Subject: Re: pad problems. > > > sorry i didnt reply to this earlier was down in boca > raton seeing the > pixies what a great show.... when i say the e pad > clips it plays the > note for a split second, its has velocity if i hit > it hard its plays > the note really loud for a split second if that > makes any sense? > > --- In xl7@yahoogroups.com, Bruddah Max > <bruddahmax@c...> wrote: > > On 10/8/04 8:18 PM, "jaxlore" <jaxlore@h...> > wrote: > > > > > thanks for the last response guys. my next ? is > i got mine as a demo > > > unit and i am not sure i might have two bad > pads. the unit looks like > > > its in pristine condition, and no other problems > but the E pad clips > > > and the G pad is totally different sensitivity > then all the other > > > pads? Any ideas. > > > > pick up the XL, shake it like an Etch-a-Sketch, > and chant "work, > dammit!" > > over and over. hey, sometimes that works. > > > > i haven't tried pad surgery yet on an XX-7, so > perhaps someone who > has can > > comment. i assume you've already checked that the > connectors to the > mobo are > > solid. not that that would cause such a problem, > but i usually do > rule-out > > troubleshooting and that'd be something done early > in that process. > > > > when you say the E pad clips, what do you mean? > > -- > > Bruddah Max > > Lord of the Dance > > > === message truncated === _______________________________ Do you Yahoo!? Declare Yourself - Register online to vote today! http://vote.yahoo.com
