Unisyn 2.1.1 Oddities with EMU XL-7 w/4 ROMs
2004-10-26 by lionelcassin
Been trying to get Unisyn working 100% with my XL-7 with varying
success. Any help would be appreciated.
Setup
- Powerbook G4 w/OSX 10.3.5, 512MB RAM
- Unisyn 2.1.1
- MOTU MIDI Express XT
- EMU XL-7 running OS 2.0 with all 4 ROM slots loaded: XL-7, World
Expedition, Vintage Keyboards, Protean Drums.
- I am using the Generic Proteus 2000 Profile as I have all the ROM
slots loaded on the XL-7
- Verified that the Sysex ID matches
Unisyn...
- Finds the XL-7 and correctly identifies the four RAM chips in the
Hardware Configuration record in Unisyn
Issue 1:
In the Devices window under the XL-7, only the User, ROM1 and ROM2
banks of presets are listed. ROM3 and ROM4 are not listed.
BUT if I go to the Unisyn menu bar and choose Devices > XL-7, I see
a huge list which lists all 4 ROMS and User. Additionally, it lists
8 banks under each(!). Of course, trying to retrieve banks 4 - 7
under any of these just generates a "bad MIDI header" message.
So, in the devices window, ROMs 3 and 4 are not listed, although
correctly identified in the hardware config record. In the Devices
menu, these ROMs are correctly listed with all their presets.
Issue 2:
If I retrieve ROM 4, Bank 0 or ROM 4, Bank 2 from the Devices menu
and then try to save that preset listing in a new document, Unisyn
crashes. I also tried selecting all, copying and then pasting into a
new blank document. Unisyn crashes as soon as I try to copy. This is
a reproducible error. Banks 1 and 3 save fine, as did all banks on
ROM 3.
Issue 3:
Every time I select a preset and send to any location (e.g., Preset
on C07A), the preset gets sent just fine, but that MIDI channel gets
disabled. So if I send "Bandvoxxe" to Preset on C07A, Bandvoxxe does
get sent just fine, but then MIDI Channel 7 In gets disabled, so I
have to go to the MIDI menu on the XL-7 and re-enable the channel.
Once I do that, I can play the preset just dandy. But if I send
another preset, the exact same thing will happen again, regardless
of the destination.
Issue 2 is actually the most pressing one because it means there's
two banks I can't manipulate in Unisyn. Issues 1 and 3 are annoying,
but can be dealt with.
If I am doing something wrong, please let me know.
Thanks a million
Lionel Cassin
Re: [xl7] Unisyn 2.1.1 Oddities with EMU XL-7 w/4 ROMs
2004-10-27 by Bruddah Max
On Oct 26, 2004, at 2:19 PM, lionelcassin wrote:
before i start let me preface by saying i only have the Beat Garden
added to my XL-7, but i've had 4 ROMs before, so i've experienced some
of these...
> Issue 1:
use the actual XL-7 profile. it has the same glitch but will work more
smoothly overall. there are subtle differences between the Command
Stations and the P2K modules.
Unisyn also only shows two ROMs on my system for direct editing, but
since you can't actually edit the ROMs anyway (just the user presets),
just copy the patch to a user preset location, "get selected" from that
location, and edit away in Unisyn.
> Issue 2:
> ROM 3.
you're right, it doesn't work properly. so - don't do this. copy the
bank from the ROM into a user bank. download the user bank into Unisyn
and save. same result, and no crashing. you'll only need to do it once.
:D
> Issue 3:
> of the destination.
by C07A i'm guessing you mean Channel 7A. do you have rechannelize to
track turned on? i've found most MIDI apps (DP4 and Unisyn included)
and the XL-7 get weird with MIDI when rechannelize is on - i only turn
it on when i've got the XL-7 as my "sequencing hub" controlling
everything else. when working with the computer, rechannelize is off.
i'm curious what sequencing app you use - if it is DP4, stop worrying
about directly editing the expansion boards (load sounds into user
presets to edit them) and use the Expansion Board Setup program that
came with DP to enable the expansion boards you have installed in the
XML patchlists.
Bruddah Max
Lord of the Dance
Re: Unisyn 2.1.1 Oddities with EMU XL-7 w/4 ROMs
2004-10-27 by lionelcassin
Thank for the quick and detailed reply. To answer some of your
questions...
1. At this moment, I do not use a computer-based sequencer. The only
sequencer I plan to use is the XL-7's, primarily in a beatbox
function.
2. The job in front of me is to winnow the 2,000 ROM patches in the
XL-7 down to a manageable set of favorites which will go into the
User banks. So I am focused on patch librarian functions right now,
and not on editing. Although that may change.
So it seems we share the basic philosophy - since you cannot access
all the ROM slots at once, get the patches you want into the User
banks and work from there.
Also, I found out that the crashing in issue 2 was due to only two
patches - one in ROM4/Bank0 and one in ROM4/Bank2. Each of these
patches were unique in that they had both a parent and a child
relationship. So I just carved around them and it worked out alright.
Thanks for the tips on the rechannelize and using the XL-7 profile.
I will give them a test at the next available moment.
Lionel
Garden
some
> of these...
> > Issue 1:
ROM2
see
lists
Devices
more
but
presets),
that
> > Issue 2:
menu
Unisyn
into a
This is
on
> > ROM 3.
Unisyn
once.
> :D
> > Issue 3:
Preset
gets
does
I
channel.
regardless
> > of the destination.
to
included)
turn
off.
worrying
that
> XML patchlists.
> Bruddah Max
> Lord of the Dance
