sorry for delay , lol in replying , also posted same although
diferent message agian , been off computer 4 a while ,
reply is :- nope all data playing & recorded on the xl7 , just the
xl7 playing back 2 or more tracks makes it happen .....
--- In xl7@yahoogroups.com, "zerolatencyproductions"
<zerolatencyproductions@...> wrote:
> Hello,
> I was thinking about a few things that might have something to do
> with the timming delays.
> You said;
> > its easy to hear this while playing tight drum tracks or notes
> with a midi clocked echo or delay as they become sloppy / messy to
> the ear once a second track is unmuted or more
> Are you running your midi through a sequencing program?
> If so there are a few things that could be causing the delays.
> Even if you aren't using a computer program but have the MIDI
cables
> connected to something, you might have a small midi loop problem
> that only manifests itself as you add more and more midi out.
> Other than that I can't think of anything if your diagnostics say
> the hardware is fine.
> Peace,
> Brandon
> --- In xl7@yahoogroups.com, "len" <len303@s...> wrote:
> > hi , iv had a problem with my xl-7 a delay problem with the
> notes?
> > as soon as i unmute any extra tracks more than 1 , i can clearly
> hear a delay on the first
> > beat or tick clocks etc, "to my trained ear"
> > delay as they become sloppy / messy to the ear once a second
track
> is unmuted or more.
> > please reply to me as this sucks & makes the instrument use less.
> > Iv run the tests for the unit & its Passes all tested ok .
> > The rom is v2 latest ? please advise?
> > Iv tryied the midi data thining on the song menus to excluded
data
> from patterns etc .
> > No joy !-(
> > Tracks playing are quantised to 16 note and play fine on there
own
> right . or one at a time.
> > anyway the tracks im playing are very simple and should play
> fine . " no CC data "
> > 1 note arp's start to sound messy after a loop to start of
> pattern "delays are bumped" ,
> > once any more than one track is playing "same delay at start of
> track problem"
> > is this a common problem with the XL-7 software revision i have??
> > whats happing dudes?
> > www.cdbaby.com/kenspocket
