how do you record your xl-7
2006-02-08 by eriksatie01
I'm working with the xl-7 and ableton live. I've programmed a few
sequences on the xl-7 and I want to record each tracks separately into
a live clip for further processing.
yesterday I started to do this task and I have a simple question about it:
do you prefer recording the xl-7  throught the digital outputs or the
analog ones? and why?
then, if you use digital, which bitrate is best (16 or 24)? I've
noticed that the volume of digital output is usually quite low, is it
normal?
thanks
davide
Re: how do you record your xl-7
2006-02-08 by jcobelas2001
Analog. Output is a bit anemic, and I warm it up with the mixer's
pres. Besides, I haven't had much luck making the digital out work,
most probably due to clocking issues.
2006-02-08 by gonzinigonz
Hi
24bits as long as everything is happy and syncs up. Trust your ears
though with that one. You might prefer the sound of the lower bit
depth of 16..
>I've noticed that the volume of digital output is usually quite low,
>is it normal?
> thanks
> davide
Yep thats normal.. logic behind that is you have potentially 128
voices sounding at once then there has to be enough headroom on the
digital output to handle it. Theres no headroom above 0dbfs, just
horrible distortion (that you proberly dont want....??!!) so scale
everything down db level wise with the digital output.
Not sure what the average is with the xx7, ive never measured it..
Cheers
Gonz
2006-02-09 by eriksatie01
> depth of 16..
I've recorded some loops with my audio card trought s/pdif at 24 bit
and all seems to be ok and in sync.
but my doubt was about the possibility of passing a "real" 24 bit
signal throught a s/pdif. is it that possible?
another doubt was about the internal audio resolution of the xl-7: is
the xl-7 capable of delivering a 24 bit true signal?
maybe these are stupid question, but I've never used s/pif so please
be kind : )
if you record a kick alone, velocity  at 127, track volume at 127, you
get  a signal of about  -10, -12 db, and less for hi hat or other
sounds. Then I normalize it at - 3 db, but I was wondering if it would
be better to record it throught the analogic output that is "hotter"
and I easily get good level without normalizing.
thanks,
davide
2006-02-10 by gonzinigonz
Hi
Looks like the S/PDIF output is 20 bit, so you recording in at 24 bit
will not really yeild any real advantage / or disadvantage.
Maybe if your multi-tracking and everything else is 24bit you will
have to stay in this format.
The extra low order bits will just get padded out.
I had issues in the past when trying to use the S/PDIF, it does seem
to depend on how the receiveing device handles the S/PDIF signal.
>is the xl-7 capable of delivering a 24 bit true signal?
Well looking at the specs in the manual..
S/PDIF specified @ 20 bit(AES is just another format, not a differant
bit depth, ie not 24bit)
It dosent usually matter which format you use as the differance is
only copy protection in consumer S/PDIF which the Pro version use's
these same bits for other purpose's.
Also the AES standard is a balanced connection, which the output on
the command station isn't.
All sample data is 16 bit, 20bit D/A converter on the main outs and
18 bit D/A on the sub outs...
The only mentioned 24 bit processing is the FX engine.
> be kind : )
No there not stupid questions, you learn these things as you come
across them. Theres loads of resource on the web on the subject.
Go as deep as you want...
>you get  a signal of about  -10, -12 db, and less for hi hat or other
>would be better to record it throught the analogic output that
>is "hotter" and I easily get good level without normalizing.
-10db or -12db isn't a bad thing. Dont forget your in the digital
domain so theres no really any noise being introduced
If you were recording a band into your PC you would have to leave
about 12db (maybe more) of headroom for the peaks (theres no headroom
above 0dbFS)if you didnt have any compression on the inputs.
Also as soon as you start doing any processing on your wav's you have
to leave headroom for that as well.
Its a compromise between good signal to noise ratio and having
enough 'bits' encoding your audio to not create to many errors.
I always used to bring everything upto peak -6db, do all the eq'ing
etc and then average normalise it upto 0db for that wall of sound
punchy dance sound... (psy trance at the time..)
Looking at the analogue world, most true pro gear has a headroom of
+24db of headroom before it clips.
Much gear has a lot less than this..
>the analogic output that is "hotter" and I easily get good level
Also you might prefer the sound of the analogue outputs?
And yes the less messing about you do with your recorded audio the
less errors start creeping in, though this will be less when encoding
at 24bits (its a bigger number representing your audio)
Cheers
Gonz
New CDs
2006-02-10 by stot ham
ATTENTION ASP Records SUPPORTERS!!!!!
The wait is over!!!!   ROGERS BROWN is on-line and ready for sale at   www.astotproductions.com
Please believe me when I say this dude is for the grown folks - If you like JAZZ or if you've never given JAZZ a try - After hearing Rogers Brown you will be hooked and begging for more.  I've played Rogers Brown at numerous occasions and the question of the night is always {Who Is That? - HE'S NICE}.   I'm excited to have him be apart of ASP Records - Check out his small bio below -
PLEASE Check out the new released ASP compilation CD -  ASP - "Track 2 Track"   &  Yung'n "Da Louisiana Purchase" (yes we did it all over)  -  Hot Tracks
It's too hot to miss  - Take a few minutes out and listen to some our joints - VISIT THE MESSAGE BOARD AT THE BOTTOM OF THE WEB PAGE AND GIVE US A SHOUT OUT!!!
Rogers Brown, leader and keyboardist of RAJAZZ Entertainment. His career is highlighted by performances with Betty Carter, Tom Browne, Ernie Watts, and Melba Moore. Aside from his performance career, he is tenured professor at Norfolk State University where he coordinates the Music and Media Program.
Rogers Brown is known in the Virginia Beach area as one of the top Jazz groups in the area. He has performed all over the world including the Bayou Classic in New Orleans, BET's Jazz Celebration in Aruba, and for celebrity hosts to include Martin Lawrence.
He's down with ASP Records NOW!!!
Please holla back & pass this to everybody you know!!!!
A-Stot
www.astot.com - WEB SITE
(210) 385-3744
Re: [xl7] Re: how do you record your xl-7
2006-02-10 by jason rodgers
As Far As Bit Depth Goes That Really Depends On The
A/d Converters On Your Input Device Not Output It Just
Lets The Sample Rate Quantize To Reproduce The Sound
Sampled In If The Digital Out Is Giving You Problems
It Is Most Likely A Clock Issue Causing Digital Jitter
--- xl7@yahoogroups.com <waveplayer@...> wrote:
> great thanks for all these informations!!
> cheers,
> davide
Do You Yahoo!?
http://mail.yahoo.com
Dont think davide has any problems with jitter or incompatable S/Pdiff
formats, though the 20bit into 24bit might need some dithering...
I had an issue when trying to feed a 16 bit connection with the XL7,
but changing to 20 bit was fine.
I cant remeber if all was ok with 24bit though..
That was on a TC D2 delay unit which i was using as a A/D and D/A. You
can change the S/PDIF format on those units.
If he can record at 24 bits then the A/D must suppport 24 bit as i'd
imagine he'd get an error when trying to record.
Most S/PDIF connections are 24 bit these days, its the current hardware
thats out there to use.
Heres some good info:-
http://www.epanorama.net/documents/audio/spdif.html
Gonz
--- In xl7@yahoogroups.com, jason rodgers <dirtybeatzproductions@...>
