cool i didnt know there was a windows version on seq24. prolly not the
answer u want but, there's a docs section on the seq24 page. i'd help
u more with it but i've only just installed it on my linux box a few
days ago. and i'm really just messing with PureData on my linux box atm.
an answer you might like is that Live 5 does send program change in
the clips in session view.
--- In xl7@yahoogroups.com, "keiodi" <ms06j@...> wrote:
> I use Ableton Live. It has the disadvantage that it doesn't send
> program change info (or it didn't I haven't checked to see if Live 6
> does) but that doesn't bother me. Another good program is Cubase. I
> own a version of it but rarely use it. I have heard a lot of good
> things about Fruity loops as well.
> I want to check out seq24 http://www.filter24.org/seq24/index.html but
> I don't know much about it and I don't know if 'll have the time.
> (BTW it's free) I don't know anything about it I can't even tell if it
> is software only or can control external gear.
> I am very partial to the built in sequencer on the XL7 and often just
> sync Ableton Live to my XL7. after working on the XL7 I'll use
> e-loader to import a sequence and then play it in live controling the
> XL7.
> --- In xl7@yahoogroups.com, "atip_akira" <tyronreid@> wrote:
> > thank you John :>
> > yea i knew a little about midi, thanks for the heads up about it,
> > fruity loops is an easy noob program to create patterns and stuff,
> > what software do you recomend for the XL7? wether it be for
> > midi,control ect. im kinda in the dark and would like to know what the
> > pros are using! thanks,
> > greatly Appriciate the help
> > -Akira-
> > --- In xl7@yahoogroups.com, "keiodi" <ms06j@> wrote:
> > > Once you inport the MIDI file to Fruity Loops are you using Fruity
> > > Loops to control the XL7 or is the MIDI patteren playing just in
> > > Fruity Loops? (is that possible with Fruity Loops? I'm not familiar
> > > with the program) sound like you are doing the second but I'm not
> sure.
> > > If it is the second option then I think your problem isn't a problem
> > > at all but is a confusion on your part on how MIDI works.
> > > MIDI is not sound it is sorta like sending sheet music. you can
play
> > > that sheet music using a violin or a piano but it will sound
> > > different. yet it is the same sheet music. When you send a midi
> > > patteren it doesn't send the sound information along with it
only what
> > > notes to play and when. Fruity loops cannout play the sounds of the
> > > XL7 it is a different instrument. Of course you can (probablly)
send
> > > the patteren as midi data back to the XL7.
> > > I Hope this helped. of course I could have totally guessed
wrongly on
> > > how you are using the XL7 and FL.
> > > John
> > > > hey b4 i start i am a real noob so pls excuse me with for my
stupid
> > > > questions lol, when i upload and import a Midi pattern into fruity
> > > > loops all the instruments change, i think this is because my
> computer
> > > > doesnt have those Rom thing installed, is there anyway i can
get the
> > > > midi files to play correctly?
> > > > also,again, when i download a midi to the xl7 from the
internet all
> > > > the instruments change, resulting in an hour of me trying to
> find the
> > > > best sound for each track. why does this happen?
> > > > again im sorry for the noobness of these question.
> > > > Please be kind, ~Akira~
