Anyone here use Song Mode? Questions...
2002-03-21 by erik_magrini@Baxter.com
Well last night was my first time attempting to use Song Mode on the XL-7 for arranging a complete tune, and I've got a couple questions for anyone that uses this more than I do. Again, this is my first time trying to compose this way, so I'm just checking to see if I'm doing something wrong here, or if other users are seeing these too:
1. ; Sometimes my mute settings would be completely reversed from what I KNOW I saved them as. This happened to me a couple of times. Sometimes the mute settings for the pattern would used, sometimes nothing would be saved as muted for that Step. Other times none of the mute settings would be used! I couldn't reproduce this every time in a predictable way, but it happened wrongly at least every other time. I'd have to erase the song and start over. Finally got it to save right last night eventually, but I don't know if it stayed that way this AM.
2. There were some times when I would select the Song I was working on, and right away before pressing any buttons the Save/Copy light would blinking telling me to save the song. I didn't change anything, or even touch the XL-7 other than to select the Song. True the Revert To Saved would clear it, but it kind of worries me that this is happening. Any ideas on what's changing in the Song that would be causing this? I know the same thing happens in Pattern mode, with the Preset on 1A showing an asterisk next to it, but this isn't the case in Song mode.
3. Also, I don't know if it's just my XL-7 or not, but when in Song Mode, everything becomes 'sluggish' for lack of a better word. Selecting a Pattern or access the menus produces a slight pause, sometimes you can see very quickly see it say < on the LCD, even though I'm not selecting another song. Sometimes after pressing the Play button there's a distinct pause before playback begins too. This is a fairly small song, so I don't think it's a memory issue..
Anyway, if anyone's got any ideas or similar stories, I'd love to hear them!
rEalm
RE: [xl7] Anyone here use Song Mode? Questions...
2002-03-21 by John Royle
I would have to agree with you on the channel mutes front! I have stuck patterns togther and set all the track mutes etc. only to find out that some of them have completely changed later on... very annoying! It's not much of an issue for me because i use it with logic audio, but if i didn't have a PC sequencer this would *really* annoy me.
Another gripe i have with song mode is that i can't for the life of me insert a pattern into the sequence (ie. before another patter). I have followed the manual, but the suggested method just won't work for me at all!
john.
Re: Anyone here use Song Mode? Questions...
2002-03-21 by nifflas
stuck
that some
not much of
have a PC
This do never happend to me. It works 100% perfect, and the mutes 'n
stuff just does that I've told it to.
Well, I had problems with this before, but that was the time I used
to press the "enter" button everytime I changed the mutes 'n stuff.
//Nifflas
