Just got an XL-7 recently & it's already fried?!
2012-04-06 by RickReid
Hi, All!
I am a new member to the group.  I need some advice.
I bought an XL-7 in perfect condition a couple of weeks ago.  I added a second ROM card and everything was fine.  Today, I tried to add a third and fourth ROM card and had troubles getting the unit to work again.  I was having some difficulty getting the ROM cards seated, so it is possible that I may have accidentally shorted something out.  At first, the display and all buttons were unlit, but there was a faint clock sound from the headphones.  Now there's no sound either.
Taking out the new ROM cards didn't solve the problem. Changing their position in the 4 slots didn't help either. I've checked to make sure all cables are seated, etc.  The only thing I could find that looked suspicions was some white residue around one of the smallest IC chips.  I honestly don't know if the residue was already there before I began tinkering or not.  Also, there's one mid-sized IC socket near the middle of the board that has no IC plugged into it.  Again, I don't know if it was already like that before I installed the ROM cards.
Do any of you have troubleshooting suggestions?  If not, is it cost effective to have an XL-7 repaired?  Any idea who can repair them?  Would I be better off just buying another one?
Thanks for any help you can provide.
Rick Reid
http://www.rickreid.com
Re: Just got an XL-7 recently & it's already fried?!
Another detail:  I had not upgraded the operating system before installing the new ROM cards.  Could this be part of the problem?  I assume it is too late to do anything about it now.  Just don't want to repeat mistakes if I get a new XL-7.
Rick Reid
Re: [xl7] Just got an XL-7 recently & it's already fried?!
2012-04-06 by Bob S.
So what were the 3rd and 4th ROM you added?
Also, I am sure there are some internal fuses in the command station, maybe mis-seating took out a fuse (hopefully not a chip).....
Bob
El Segundo, CA
On Apr 5, 2012, at 8:22 PM, "RickReid" <rickreidvo@...> wrote:
> Hi, All!
> Rick Reid
2012-04-06 by craig ward
Email epr electronics. They talk about repairs on their site.
Bob
El Segundo, CA
On Apr 5, 2012, at 8:22 PM, "RickReid" <rickreidvo@gmail.com> wrote:
Hi, All!
Rick Reid
2012-04-07 by RickReid
Thanks for the replies. I'll check on the repair resource.
The ROMs that worked okay were the include Xtreme Lead and the Techno ROM.  The new ROMs  I was trying to add were Composer, which seemed to work okay and a 9090 Orbit ROM which gave me an error message about having two ROMs with the same ID, or something like that.
I think were I probably screwed up -- besides not understanding how to easily install the ROM cards, was that I probably left the AC power plugged in and turned on at some point, by mistake, because I was testing each ROM in different sockets to troubleshoot why they weren't all working when installed at the same time.
I really, really want this thing to work for an upcoming live theater production I'm involved with.  So I went ahead and bought another XL-7 from eBay.  That will give me some time to get this one fixed, if possible, then I'll keep it as a backup or re-sell it.  The one I just bought already has the operating system upgraded.  So, I won't have to mess with that.
Ouch!  That was an expensive goof!
Rick Reid
Re: [xl7] Re: Just got an XL-7 recently & it's already fried?!
2012-04-07 by Bob S.
You just answered the question that gave the reason you fried the XL-7.
The Orbit 9090 ROM is not electrically compatible with the Proteus 2000 series and Command Stations. The Orbit 9090 is the old series. There was a discussion thread about this in this group or the P2K Yahoo group, I can't find it at this moment.
Do not use non-Proteus 2000 ROMs in the Proteus 2000 systems.....or as others have found, you will fry the main board...
Bob S.
El Segundo, CA
Sent: Saturday, April 07, 2012 12:40
Subject: [xl7] Re: Just got an XL-7 recently & it's already fried?!
Rick Reid
2012-04-08 by Dumeril
I will bet that something got damaged when power was run thru it with a card not fitted properly.  An electronic circuit is dependent on components being where they're designed to be and bad things can happen when they're not.  (As an aside, there used to be a computer company called Tandem whose claim to fame was fault tolerance of their computers.  For demos, they used to walk up to a running computer and pull boards out of them and the computer would keep churning along as if nothing happened.  On a non-fault tolerant computer, that would kill it.)  Anyway, I think you'll need to have the Command Station serviced.  I would check the fuse on the power supply; its possible that the fuse blew to save the board which would be great.  I know that EPR works on E-mu stuff (http://www.eprelectronics.com/).
Good luck!
D7
--- In xl7@yahoogroups.com, "RickReid" <rickreidvo@...> wrote:
> Hi, All!
> Rick Reid
2012-04-08 by Bob S.
Sure, this might have happened but specifically, it was the Orbit 9090 ROM that would have blown the main board, this has been documented and occurred before with others.  Search "rom damage" in our message database and see what you should not be doing....
Bob S.
El Segundo, CA
> Good luck!
> D7
> > Hi, All!
> > Rick Reid
2012-04-08 by RickReid
Thanks for the info.  I will definitely do more research before sticking things in my musical instruments from now on!
Rick Reid
> Bob S.
> El Segundo, CA
2012-04-09 by steve_the_composer
A lot of people have mentioned epr electronics over the years. I have only gotten sale roms from them, no repairs. But it might be worth your while to contact them (depending on where you are located).
Sorry to hear you fried your new E-Mu. Maybe it can be given new life.
> Rick Reid
> > Bob S.
> > El Segundo, CA
2012-04-18 by Ricard
Leaving the power on while plugging or unpluggning ROM cards could very well have fried the main board, especially if you didn't get the connectors lined up properly from the start. When inserting or removing components or modules inside a piece of electronics equipment the power should always be off.
That said, the power supply units in these machines are notorious for failing after a while. A couple of months ago someone had success getting his XL-7 power supply unit fixed by someone who specializes in power supply unit repairs. Especially after adding ROMs, the additional power required could be just enough to cause a marginal power supply unit to fail. Replacement is usually out of the question because the spares have been sold out long ago, and although not really rocket science these days, there are no equivalent power supply units that can just be plugged in.
I've never bought anything from EPR electronics, but I had a long discussion with them regarding a problem I had with my XL-7 and they were very helpful all the way. They were willing to sell me a new mainboard for my unit, but in the end I declined, since I could get another second hand unit locally for what it would have cost in shipping and import duty. It's a different story if you live in the US though, there a replacement main board would probably be worth while.
Problem of course is knowing if the power supply or mainboard has died. EPR can most likely help you there too, but you'd have to send your unit to them.
RE: [xl7] Re: Just got an XL-7 recently & it's already fried?!
2012-04-18 by craig ward
I think it has been said before that there is not enough ventilation around the power supply. Has anyone had any luck installing a cooling fan inside on of these babys??
To: xl7@yahoogroups.com
Date: Wed, 18 Apr 2012 18:28:42 +0000
