Here's the table from the sysex manual (v. 2.2). If you don't have it, its in the files section. If you have an external controller that can send out sysex data on the fly, you might try these. I am not sure if changing these parameters when FXA/FXB are sounding causes any audio glitches, but that might be desirable in some types of music.
Steve
Parameter ID
(RESERVED) id = 512 (00h,04h)
MASTER_FX_A_ALGORITHM id = 513 (01h,04h) min = 1; max = 44;
MASTER_FX_A_DECAY id = 514 (02h,04h) min = 0; max = 90;
MASTER_FX_A_HFDAMP id = 515 (03h,04h) min = 0; max = 127;
MASTER_FXB_SEND_FXA id = 516 (04h,04h) min = 0; max = 127;
MASTER_FX_A_MIX_SEND 1 id = 517 (05h,04h) min = 0; max = 100;
MASTER_FX_A_MIX_SEND 2 id = 518 (06h,04h) min = 0; max = 100;
MASTER_FX_A_MIX_SEND 3 id = 519 (07h,04h) min = 0; max = 100;
MASTER_FX_B_ALGORITHM id = 520 (08h,04h) min = 1; max = 32;
MASTER_FX_B_FEEDBACK id = 521 (09h,04h) min = 0; max = 127;
MASTER_FX_B_LFO_RATE id = 522 (0Ah,04h) min = 0; max = 127;
MASTER_FX_B_DELAY id = 523 (0Bh,04h) min = 0; max = 127;
MASTER_FX_B_MIX_SEND 1 id = 524 (0Ch,04h) min = 0; max = 100;
MASTER_FX_B_MIX_SEND 2 id = 525 (0Dh,04h) min = 0; max = 100;
MASTER_FX_B_MIX_SEND 3 id = 526 (0Eh,04h) min = 0; max = 100;
MASTER_FX_A_MIX_SEND 4 id = 527 (0Fh,04h) min = 0; max = 100;
MASTER_FX_B_MIX_SEND 4 id = 528 (10h,04h) min = 0; max = 100;
--- In xl7@yahoogroups.com, "steve_the_composer" <smw-mail@...> wrote:
> If you are looking for a way to have CCs change FX settings other than the send amounts, I don't think that is possible. It might be possible with sysex; check out the sysex manual to see if the FX parameters are listed. (I will look myself when I have a chance.)
> I have used !FX presets on a designated FX channel to switch FXA/FXB settings.
> Steve
> --- In xl7@yahoogroups.com, "ackack1020" <sackley85@> wrote:
> > Set this up as well. Definitely fun for live tweaking. Does anyone know of a way to control the effects settings (feedback, etc...)? Is that possible on the CS?
> > Easy.
> > Scott
