Steps to load SMF GM midi file
2012-08-15 by intrepidpete
I was having issues previously trying to load SMF GM midi files into Command Station (CS), but I think I have it all figured out now. Here are the steps:
Open the SMF midi file in your sequencer/DAW software.
Save the song as midi format 1.
Remove all sysex.
Set all 16 tracks and channels to be in logical sequential order, with track and channel numbers matching, so for example track 9 is set to channel 9.
If there are any tracks with volume set to 0, delete those, since it is probably something like a karaoke lead vocals track with notes that trigger lyrics that you won't be able to see on the CS anyway.
Filter out all program changes from all tracks, since once you get the song onto the CS, you will choose your own voice patches depending on which ROM cards you have.
Don't worry if the drum track (usually 10) sounds stupid, like being played using a piano voice. Once the song gets onto the CS, you can select a good sounding drum kit.
If you have any tracks with strange sounding notes up in the upper 2 octaves, it is probably using Yamaha XG/XF voices. Those voices have "extras" like fret sounds and such in the upper octaves. Simply filter out notes above C8 on that track and then it will sound OK. Unless of course someone wants to program XG patches that have all those "extras" in the upper octaves :-) That's way beyond my skill level.
Set the bank on every tack to 0, so when you get the song onto the CS, you don't have a bunch of tracks that won't play because of unsupported bank/program numbers. Note that if you have the ZR card, you can set it to the GM bank for that card, since I believe the ZR card is the only one with a GM bank.
Now save the file and use E-Loader to put it onto the CS. As an aside, I got this idea from someone in the group and it works well: Use E-Loader to load a blank song into every slot, changing the name alphabetically every 10 slots, so you have "Artist A" in 10 slots, then "Artist B", etc. Later, load SMF songs into the appropriate slot, based on artist, using next open slot in the back of the section of 10. So if I want the Wilson Phillips song Hold On, I scroll till I see "Artist W", then scroll forward a few more till I see "WPhillips HoldOn".
Note on E-Loader and midi interfaces: E-Loader does not work right with cheapo midi interfaces. My $10 Amazon USB midi interface would not work. I got a $50 M-Audio Midisport, and now E-Loader works. Since I use an old Win98 laptop in my midi chain to run old DOS based midi sysex and librarian software and do stuff with floppy disks, I chose the Midisport, since you can still download Win98 drivers for it.
Re: [xl7] Steps to load SMF GM midi file
2012-08-15 by Bruno
2012/8/15 intrepidpete <peteflagg@...>:
For 50$ (or a bit more) it should be possible to get second-hand
eMagic AMT-8 (or AMT-4). They work like a charm with E-Loader (and not
only).
Bruno
Re: Steps to load SMF GM midi file
2012-08-16 by steve_the_composer
Just a footnote: I have heard of people who have gotten the Unitor drivers/software (for eMagic midi interfaces) to work on post-Win98 PCs. However, I have not been able to get them to work with eMagic's MT-4 on either XP or Win7.  I am guessing it would probably still work on a Win98. If someone were to invest $50 (or more) in an eMagic interface, I recommend making sure there is a refund option in case it doesn't meet your needs.
Steve
> only).
> Bruno
Re: [xl7] Re: Steps to load SMF GM midi file
2012-08-17 by Bruno
2012/8/16 steve_the_composer <smw-mail@...>:
That's strange - I am using my Unitor8s on XP, and recently got an
AMT8 to use it as a spare (or gig one). I cannot say I haven't had any
issues though, as installing multiple cascaded Unitors on Windows can
be a pain in the $a in certain situations (works OK on Mac though, but
you need at least one USB enabled, since Mac OS X doesn't support
connecting Unitors thru serial port), but given enough patience it's
doable, and once done, continues to work. You will probably need the
latest drivers (2.27).
MT4 can be a different beast tho: according to SoS "Unlike the same
company's AMT8 (reviewed in SOS January 2000), the MT4 doesn't feature
Emagic's Active MIDI Transmission (which can improve MIDI timing when
used with compatible software), so its timing resolution will be
limited by the resolution of the USB port to which it is connected.",
so its drivers can be different, thus not supported on 98+ versions of
Windows.
Bruno
2012-08-20 by steve_the_composer
Now that you mention it, my MT-4 had problems with my Casio Digital Horn which output a stream of AT based on breath. So the explanation here makes sense. Thanks.
Steve
[snip]
> Windows.
