Understanding envelop time quick edits
2013-12-13 by <ricard2010@...>
There's something I've been wondering about for a while: When editing envelope time parameters, such as attack or decay, a value of 0 means 'instantaneous', whereas higher values result in longer times.
However, when setting up a patchcord in order to map a MIDI controller (i.e. quick edit knob) to an envelope time, the resulting 'amount' value is normally set to a negative number. This results in a knob position of far left giving a corresponding time of 0, and advancing the knob results in longer times, as would be expected. What I don't understand is why the patchcord amount in this case must be set to a negative number; that would tend to shorten the corresponding time parameter rather than lengthen it I would have thought.
Is there any explanation for this?
/Ricard
Re: Understanding envelop time quick edits
2013-12-13 by steve_the_composer
This is interesting. I never played with this systematically before. I seemed to duplicate your results. My gut inclination was to say its coded as an inverse relationship.  But That didn't feel right, so I started playing with level.
Here's what I have right now (using a riff to hear what's going on):
MidiE -> VEnvAtk + 022 [I also tried other values]
Attack1 26 9%
When MidiE knob is down full (counter clockwise) which I would assume is 0, the short attacks are very short.As I turn MidiE clockwise, the attack seems to take longer.
At Attack1 26 0%, MidiE has no effect. Leaving MidiE up full, changing the level from 0% to 100% has no effect. However, with the level at 100%, lowering MidiE seems to make the attack take longer.
After a long day, my brain is not at its peak, but clearly level is part of the equation, too. I am not sure what all this means, and I realize it doesn't explain what's going on, but I thought as long as I played around, I'd share my results and maybe it will help to find an explanation.
Steve
> /Ricard
More testing (Switched to Q Bass ROM Instrument on one of my ROMS to really hear the attack):
MidiE -> VEnvAtk -022 [negative numbers = inverse]
Attack1 7 0%
Turning MidiE from 0 to 127 (clockwise), the attack time gets longer.
MidiE -> VEnvAtk  +068
Attack1 112 1%
Turning MidiE from 0 to 127 (clockwise), the attack time gets shorter.
Conclusion:
Its counter intuitive (i.e., backwards).
Steve
