[xl7] Rec Arpegio Midi Data into Cubase
2001-09-20 by kudos
Hi everyone, can the XL-7 perform such a task or am I asking too much.
Q. If I play a down/up arp' preset say by holding down a Gmajor chord is/can every note/sound produced recorded as midi (wether the arp' is set to play over 1, 2, or 3 octaves)...basically so I can edit it within cubase, copying this midi info to 3 or 4 tracks and asign them different sounds e.g. another preset sound from the XL-1 or soundfont or soft synth; or will the three notes that make up Gmajor be the only midi note info that gets recorded.
If yes or no, how is it done; can it be done
Hope I've been clear.
thanks all
frank
Re: [xl7] Rec Arpegio Midi Data into Cubase
2001-09-20 by Sean Wilhelmsen
Yes it can be done.
Press the Arp Button. Go to Screen #3, "ARP/RIFF MIDI out". Set it to  -
Transmit arps.
Your Sequencer will record both the notes being held down and the
arpeggiated ones.
To remove the held notes, you'll have to edit the track and erase the
notes with the long duration's. They should be easy to spot and are
probably located at tick 0 of the bar you first recorded into. Also,
make sure your Xl-7's tempo is the same as your software Sequencer or
better yet set the Xl-7 to slave to the Soft Sequencer via MIDI clocks.
If you have input quantize on, it may faster and easier just to match
tempos if you haven't already synched your two Sequencers together.
sean at e-mu / ensoniq
