Re: [xl7] Thanks Sean Wilhemsen!..Rec Arpegio Midi Data into Cubase
2001-09-20 by kudos
Brilliant Sean! Well explained...thanks very much. Kudos ----- Original Message -----
From: "Sean Wilhelmsen" <seanw@...> To: <xl7@yahoogroups.com> Sent: Thursday, September 20, 2001 7:17 PM Subject: Re: [xl7] Rec Arpegio Midi Data into Cubase > > To remove the held notes, you'll have to edit the track and erase the > notes with the long duration's. They should be easy to spot and are > probably located at tick 0 of the bar you first recorded into. Also, > make sure your Xl-7's tempo is the same as your software Sequencer or > better yet set the Xl-7 to slave to the Soft Sequencer via MIDI clocks. > If you have input quantize on, it may faster and easier just to match > tempos if you haven't already synched your two Sequencers together. > > sean at e-mu / ensoniq > > To unsubscribe from this group, send an email to: > xl7-unsubscribe@yahoogroups.com > > > > Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/ > >
