Re: [xl7] Saving pattern for patches set-up
2015-11-29 by Greg Waltzer
You can save the assignment of presets to channels as a multi.
On 11/29/2015 2:22 AM, mindkil@... [xl7] wrote:
> Hello!
> I would like to save a set-up of patches on different channels on my
> XL-7 - eg. Ch.1 = Preset 001, ch.2 = Preset 024, Ch.3 = Preset... so
> that I can easily have access to different sounds while playing live,
> by switching to the appropriate Channel.
> Unfortunately when I save the Pattern, it doesn't save the set-up of
> instruments on the Channels I didn't record any sequencer information
> - it gets lost when I turn off the XL-7. Is there some workaround for
> this?
> Bests,
> Gas
Re: Saving pattern for patches set-up
2015-11-30 by smw-mail@...
In addition to Greg's suggestion there's another one that involves basically setting up patterns as templates with dummy data so the channel data gets saved with the pattern. Some background: when saving a pattern, if there is no data on a particular track, it gets interpreted as an empty track. I have used this technique to preserve (for example) channel assignments, etc.
In addition to your preset data, you could enter CC 7 as 127 on each channel (or any other data). Then save the pattern.Hope that helps.
--Steve
Yes. Also, you might want to test inserting presets as data to see if that is enough dummy data to prevent tracks from going into an empty/default state when saved. I was wondering about that. I mght test it myself and possibly post some template examples.
--Steve
Re: [xl7] Re: Saving pattern for patches set-up
2015-12-20 by Sean Wilhelmsen
The preset is saved when you engage record. It's saved as data, pre start of the pattern.  If you make 16 dummy tracks for a one measure pattern with the desired presets assigned to the tracks , record without notes and then save. The next time you select the pattern it should load all of the presets, volume, and pan information without having to press start. As Steve mentioned you can then uses this as a template for further setups.
Sean
    On Monday, November 30, 2015 4:43 AM, "smw-mail@... [xl7]" <xl7@yahoogroups.com> wrote:
     Yes. Also, you might want to test inserting presets as data to see if that is enough dummy data to prevent tracks from going into an empty/default state when saved. I was wondering about that. I mght test it myself and possibly post some template examples. --Steve  #yiv7282243476 #yiv7282243476 -- #yiv7282243476ygrp-mkp {border:1px solid #d8d8d8;font-family:Arial;margin:10px 0;padding:0 10px;}#yiv7282243476 #yiv7282243476ygrp-mkp hr {border:1px solid #d8d8d8;}#yiv7282243476 #yiv7282243476ygrp-mkp #yiv7282243476hd {color:#628c2a;font-size:85%;font-weight:700;line-height:122%;margin:10px 0;}#yiv7282243476 #yiv7282243476ygrp-mkp #yiv7282243476ads {margin-bottom:10px;}#yiv7282243476 #yiv7282243476ygrp-mkp .yiv7282243476ad {padding:0 0;}#yiv7282243476 #yiv7282243476ygrp-mkp .yiv7282243476ad p {margin:0;}#yiv7282243476 #yiv7282243476ygrp-mkp .yiv7282243476ad a {color:#0000ff;text-decoration:none;}#yiv7282243476 #yiv7282243476ygrp-sponsor #yiv7282243476ygrp-lc {font-family:Arial;}#yiv7282243476 #yiv7282243476ygrp-sponsor #yiv7282243476ygrp-lc #yiv7282243476hd {margin:10px 0px;font-weight:700;font-size:78%;line-height:122%;}#yiv7282243476 #yiv7282243476ygrp-sponsor #yiv7282243476ygrp-lc .yiv7282243476ad {margin-bottom:10px;padding:0 0;}#yiv7282243476 #yiv7282243476actions {font-family:Verdana;font-size:11px;padding:10px 0;}#yiv7282243476 #yiv7282243476activity {background-color:#e0ecee;float:left;font-family:Verdana;font-size:10px;padding:10px;}#yiv7282243476 #yiv7282243476activity span {font-weight:700;}#yiv7282243476 #yiv7282243476activity span:first-child {text-transform:uppercase;}#yiv7282243476 #yiv7282243476activity span a {color:#5085b6;text-decoration:none;}#yiv7282243476 #yiv7282243476activity span span {color:#ff7900;}#yiv7282243476 #yiv7282243476activity span .yiv7282243476underline {text-decoration:underline;}#yiv7282243476 .yiv7282243476attach {clear:both;display:table;font-family:Arial;font-size:12px;padding:10px 0;width:400px;}#yiv7282243476 .yiv7282243476attach div a {text-decoration:none;}#yiv7282243476 .yiv7282243476attach img {border:none;padding-right:5px;}#yiv7282243476 .yiv7282243476attach label {display:block;margin-bottom:5px;}#yiv7282243476 .yiv7282243476attach label a {text-decoration:none;}#yiv7282243476 blockquote {margin:0 0 0 4px;}#yiv7282243476 .yiv7282243476bold {font-family:Arial;font-size:13px;font-weight:700;}#yiv7282243476 .yiv7282243476bold a {text-decoration:none;}#yiv7282243476 dd.yiv7282243476last p a {font-family:Verdana;font-weight:700;}#yiv7282243476 dd.yiv7282243476last p span {margin-right:10px;font-family:Verdana;font-weight:700;}#yiv7282243476 dd.yiv7282243476last p span.yiv7282243476yshortcuts {margin-right:0;}#yiv7282243476 div.yiv7282243476attach-table div div a {text-decoration:none;}#yiv7282243476 div.yiv7282243476attach-table {width:400px;}#yiv7282243476 div.yiv7282243476file-title a, #yiv7282243476 div.yiv7282243476file-title a:active, #yiv7282243476 div.yiv7282243476file-title a:hover, #yiv7282243476 div.yiv7282243476file-title a:visited {text-decoration:none;}#yiv7282243476 div.yiv7282243476photo-title a, #yiv7282243476 div.yiv7282243476photo-title a:active, #yiv7282243476 div.yiv7282243476photo-title a:hover, #yiv7282243476 div.yiv7282243476photo-title a:visited {text-decoration:none;}#yiv7282243476 div#yiv7282243476ygrp-mlmsg #yiv7282243476ygrp-msg p a span.yiv7282243476yshortcuts {font-family:Verdana;font-size:10px;font-weight:normal;}#yiv7282243476 .yiv7282243476green {color:#628c2a;}#yiv7282243476 .yiv7282243476MsoNormal {margin:0 0 0 0;}#yiv7282243476 o {font-size:0;}#yiv7282243476 #yiv7282243476photos div {float:left;width:72px;}#yiv7282243476 #yiv7282243476photos div div {border:1px solid #666666;height:62px;overflow:hidden;width:62px;}#yiv7282243476 #yiv7282243476photos div label {color:#666666;font-size:10px;overflow:hidden;text-align:center;white-space:nowrap;width:64px;}#yiv7282243476 #yiv7282243476reco-category {font-size:77%;}#yiv7282243476 #yiv7282243476reco-desc {font-size:77%;}#yiv7282243476 .yiv7282243476replbq {margin:4px;}#yiv7282243476 #yiv7282243476ygrp-actbar div a:first-child {margin-right:2px;padding-right:5px;}#yiv7282243476 #yiv7282243476ygrp-mlmsg {font-size:13px;font-family:Arial, helvetica, clean, sans-serif;}#yiv7282243476 #yiv7282243476ygrp-mlmsg table {font-size:inherit;font:100%;}#yiv7282243476 #yiv7282243476ygrp-mlmsg select, #yiv7282243476 input, #yiv7282243476 textarea {font:99% Arial, Helvetica, clean, sans-serif;}#yiv7282243476 #yiv7282243476ygrp-mlmsg pre, #yiv7282243476 code {font:115% monospace;}#yiv7282243476 #yiv7282243476ygrp-mlmsg * {line-height:1.22em;}#yiv7282243476 #yiv7282243476ygrp-mlmsg #yiv7282243476logo {padding-bottom:10px;}#yiv7282243476 #yiv7282243476ygrp-msg p a {font-family:Verdana;}#yiv7282243476 #yiv7282243476ygrp-msg p#yiv7282243476attach-count span {color:#1E66AE;font-weight:700;}#yiv7282243476 #yiv7282243476ygrp-reco #yiv7282243476reco-head {color:#ff7900;font-weight:700;}#yiv7282243476 #yiv7282243476ygrp-reco {margin-bottom:20px;padding:0px;}#yiv7282243476 #yiv7282243476ygrp-sponsor #yiv7282243476ov li a {font-size:130%;text-decoration:none;}#yiv7282243476 #yiv7282243476ygrp-sponsor #yiv7282243476ov li {font-size:77%;list-style-type:square;padding:6px 0;}#yiv7282243476 #yiv7282243476ygrp-sponsor #yiv7282243476ov ul {margin:0;padding:0 0 0 8px;}#yiv7282243476 #yiv7282243476ygrp-text {font-family:Georgia;}#yiv7282243476 #yiv7282243476ygrp-text p {margin:0 0 1em 0;}#yiv7282243476 #yiv7282243476ygrp-text tt {font-size:120%;}#yiv7282243476 #yiv7282243476ygrp-vital ul li:last-child {border-right:none !important;}#yiv7282243476
