Unwanted send to effects
2016-01-23 by brian.grassfield@...
Hi! I have a question if someone experienced the same: how the effects mix-in could set apart with the common way? I started with a rom patch and my global was set to use fx of the  patch used on channel 1. Then I recalled the patch to edit and set all fx send to 0% and... it sends a bit anyway! So literally if I set this patch to fx source then I cannot make dry sounds. I checked this with many other patches and patterns, but this was the only which behaved this way. Can someone make an advice, what to see for fx send amount?
Re: Unwanted send to effects
2016-01-24 by brian.grassfield@...
Hi, thanks for the answer. For details I have to say, FX are welcome in my setup, but now I can't make dry sounds if I set in the globals to use the patch on ch1 settings. Of course it's working as expected if I set back to use global FX, but it means I cannot use different setting in different patterns, that is not what I want. So now the case is I set to use ch1 patch FX, every send is 0%, but yet it clearly affects on the sound. (delays working)
